(Topic ID: 236512)
Sound not working on Eight Ball Deluxe LE
By Daditude
5 years ago
#1 5 years ago
I have an Eight Ball Deluxe LE that has lost its speech. It was working fine then it just stopped. I have disconnected and reconnected pins, bought new sound chips, checked fuses, check speaker wires, cleaned (brushed) u8 and j2 and j1.
The board doesnt look that old, but i could be wrong.
Any suggestions?
1550524111961405497133 (resized).jpg1550524111961405497133 (resized).jpg15505241376451908007624 (resized).jpg15505241376451908007624 (resized).jpg1550524166413898809216 (resized).jpg1550524166413898809216 (resized).jpg
#2 5 years ago
I should mention that i have also tried the pots on the board and the coin door. There is some static/humming, but no speech.
#4 5 years ago
Hi thanks for buying the chips from me. Im sorry they didnt fix your issue. Next step would be a recap as those look like original caps.
#5 5 years ago
Does the LED on the Squawk and Talk sound board flash 5 times on powerup?
Is that a new TMS5200 speech chip I see installed at U8?
What test equipment have you got? Oscilloscope, logic probe, multi-meter..
What happens when you press the test button on the sound board? Normally it speaks a few phrases for about 10 seconds then ends with a single tone from another sound chip.
Are other sound effects (not speech) working?
What are you getting on TP9 when speech should be playing and when it shouldn't?
Are you measuring -5VDC at TP4 which is for the speech chip?
#6 5 years ago
Quench has all the things you need to check. Since the game was working and suddenly quit look for the most basic things first. Make sure the speaker is OK and the pot on the front door.
#7 5 years ago
Here is what I would do for a "no sound" condition:
Look for bad solder joints at the connectors and at those large diodes (the diodes get hot).
Recap the board.
Replace those cheap trimpots. They go bad internally.
Check/replace the the volume control on the coin door.
Check/replace the speaker.
#8 5 years ago
My EBD ST board was doing the same yours was. I mailed it out to Coin Op Cauldron. When it returned it was working. Needed new caps and some other stuff.
I'm a lazy guy so sending it out made the most sense. Like 80 bucks and a couple months and I had a working sound board.
#9 5 years ago
I will start checking these things out. If need be, where is the best place to get a squawk and talk sound board?
#10 5 years ago
Quoted from Quench:
No. It flashes once...pauses...then 3 more times.
I have no idea. It was on there when i got it.
Of those three, only a multimeter
Nothing.
All i hear is buzzing
Im not sure what you mean by this. There is nothing coming from t9 (it is a metal loop, right?)
I will check this and get back
#11 5 years ago
Quoted from Daditude:
I do not believe these are available. So focus on repairing yours.
#12 5 years ago
does the g.i. on the playfield work? these boards need the ac voltage from the g.i.
#13 5 years ago
Quoted from Astill:
Yes, the G.I. AC voltage is used to create the -5VDC supply rail for the speech chip.
#14 5 years ago
Quoted from Astill:
Quoted from Quench:
All GI works.
#15 5 years ago
Nothing.
I dont seem to be getting anything from tp4...and with only 4 lights at the led, it looks like maybe that or the tms5200 could be the issue.
#16 5 years ago
Yes with 4 LED flashes, it appears to be failing at the TMS5200 test.
Test point TP4 should have negative 5 volts "-5VDC" which is a supply rail for the TMS5200. If you don't measure any voltage on TP4 it might explain why the TMS5200 test is failing.
The -5VDC comes from the voltage regulator "VR2" on the sound board. Check that the VR2 input is getting voltage to start with. With your multi-meter set to DC voltage, black lead hooked up to ground (you can use TP1 on the sound board which is a ground point) and put the red meter lead on the right leg of the electrolytic capacitor "C38" which is directly above the sound board connector. What negative voltage do you read there?
#17 5 years ago
Quoted from Quench:
TP1 and C38 measure 4.2
#18 5 years ago
Maybe i am testing tp4 incorrectly. What is the correct way to test it?
#19 5 years ago
That voltage is too low. I'd be expecting somewhere between -11VDC and -15VDC.
Initial hunch is that the electrolytic capacitors at C37 and C38 are not charging enough and are bad or one of diodes CR7 or CR8 is faulty.
Set your multi-meter to read DC voltage. If your meter is not auto-ranging set it to the 20VDC range.
Hook the black meter lead to TP1 on the sound board which is ground.
Then touch the red meter lead on the sound boards test point TP4.
What measurement do you get? Please also list if the minus sign comes up on the meter display with the voltage measurement.
As @Astill mentioned above, it might be worth replacing the electrolytic capacitors on this sound board.
#20 5 years ago
Quoted from Quench:
I eork all day until very late. I will test it again when i get home. Thanks for the help.
#21 5 years ago
Quoted from Quench:
TP4 is reading -4.9
#22 5 years ago
TP4 is reading -4.9
That's better.
When you press the self test button on the sound board, do you hear a tone beep after about 10 seconds? The tone comes from a different (not speech) sound chip on the board.
Can you swap the two 6821 chips with each other at U7 and at U11 (they're the same chips). Reinstall them in the same direction you removed them. One of these chips communicates with the TMS5200 speech chip. See if the LED flash sequence changes.
#23 5 years ago
Quoted from Quench:
That's better.
There is no tone beep after 10 seconds, but switching the chips did yield 5 flashes
#24 5 years ago
Your board looks in good condition but maybe the chip sockets have seen better days.
Can you post some picture of the original ROMs you pulled from this board? Just want to see what condition the legs were in.
When you press the self test button, do you hear any clicking noises or anything? In case the button isn't working press it a few times incase it's internally dirty and then restart the machine.
On Eight Ball Deluxe, 10-15 seconds after pressing the self test button on the sound board and it's performed its sound test, the board will reboot and perform the self test LED flashing again. Are you seeing the LED flashes 10-15 seconds after pressing the self test button?
BTW, what happens when you put the game in sound test mode by pressing the little button inside the coin door four times?
#25 5 years ago
From the picture it looks like there is oxidation on the leads of at least some of the IC chips. Those may need to be cleaned and it may be time for new DIP sockets. I have a similar board in my Elektra and am getting ready to rebuild another that was missing several ICs. In the past I've had to replace a bad 6810 to get a sound card working.
#26 5 years ago
Can you post some picture of the original ROMs you pulled from this board? They look pretty good to me, but i will post them.
I hear nothing
Yes
No sound
#28 5 years ago
- Are you seeing the LED flashes 10-15 seconds after pressing the self test button?
Yes
Ok, so it may be pointing more to a problem in the audio mixer/amplifier stages. If you adjust the two small pots on the sound board up and down, do you get any scratchy noises through the speaker?
#29 5 years ago
Quoted from Quench:
Yes. I can get some humming and scratching noises, but no speech
#30 5 years ago
We can presume the amplifiers are somewhat working if while adjusting the pots you get scratchy noises.
Inside the head there is a bare wire braid running along the bottom. This is a ground strap. Put your black multi-meter lead under the wire braid at a tight point so it's connected to ground and leave it there.
Set your multi-meter to DC voltage. If it isn't an auto-ranging meter set it to 2 volts DC.
Put the red meter lead on test point TP9 on the sound board. You should measure a steady voltage around 1.33 volts. What do you read?
Press the test button on the sound board. Do you see the voltage on TP9 change a little bit until the LED starts flashing again? Roughly what range does the voltage change between?
#31 5 years ago
It looks like the caps are the next step. I will get them done and report back.
#32 5 years ago
The tms chip has silver legs. Remove and clean the tarnish off and do the caps and pots. I bet it will work.
#33 5 years ago
Quoted from Fordiesel69:
I already tried it and no dice. I had a local restorer/repairer come out and he said it looks like the caps are the issue, so i sent my board out to get fixed.
Hopefully all should work afterward. I will report back.
10 months later
#34 4 years ago
So what happened? I have the same exact issue...
#36 4 years ago
Well I got it fixed without replacing any caps. Here’s what I did:
1. Pulled all the IC chips, cleaned them and reseated them.
2. I swapped the IC chips starting with “MC” chips that are identical.
3. Cleaned the pots.
4. Reflowed the solder on just the connectors on the board.
5. Pulled C15 cap and tested it. Passed. Put it back.
6. Reseated the cables.
...and that’s about it and it works.
#37 4 years ago
Still having an issue with scratchy sounds. Voices work fine. Any ideas on that?
$ 18.95
$ 29.99
Pinball Shark
$ 69.00
Pinball Pimp
$ 18.00
$ 119.95
Allteksystems
$ 33.95
$ 8.00
Third Coast Pinball
$ 69.00
Pinball Pimp
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/sound-not-working-on-eight-ball-deluxe-le and we tried optimising it for printing. Some page elements may have been deliberately hidden.
