My bad girls by gottlieb is starting to act up. The sound works fine and than cuts out after playing a game or two. Before it cuts completely out, the sounds start getting all messed up. Eventually the sound stops all together except for a few sound effects. When the sound cuts out, the red LED on the sound board either stays lit solid and stops blinking or it goes out and stays out. If I reset the game, It works for a little bit but than does the same thing.
I tried reseating the roms and I also repined both connectors on the soundboard with new trifuricon connectors. I tested continuity for all wires that mount to the sound board. I also replaced the ribbon cable. The power supply has solder reflowed and a new potentiometer on it. I also reflowed solder on the header pins in the sound board. None of this seemed to fix the issue. I could get further if I knew how to test the connectors on the soundboard for the proper voltage. I have the system 80 guides but did not find anything regarding those connectors and what voltages I should be seeing. If I can find out what numbers I am supposed to be seeing on what pins, I could atleast see if the problem is before the sound board or if it lies in the sound board itself. The two connections are label APJ1 and APJ2. Anyone know what they are supposed to show? Thanks.
