my uncle bought the brand new hot wheels pinball. great game but when the game is sitting idle, the buzzing noise that comes thru the speakers is annoying! what causes this? non-shielded speakers? crappy wiring?
Hi @Anduper...
Certainly not normal behavior, so something is slightly wrong. American Pinball Support will be happy to help you/your uncle get this resolved. I'd suggest filing a service request ticket at <https://www.american-pinball.com/support/service/>, and our team will help y'all fix the problem.
Just sold a Hot Wheels with a similar problem, can you tell me if it was ever resolved? And what the fix was?
Quoted from Butch2099:Just sold a Hot Wheels with a similar problem, can you tell me if it was ever resolved? And what the fix was?
I just got one yesterday with the same issue, will file a support request once my serial is confirmed
Hopefully it a quick fix that we can post publicly!
LOOOOVE the pin though.
I’ve had mine for months. Never had a sound issue. Maybe check the noise filter coming from the amp.
I got a response from American pretty quickly. I checked all the cables and turned down the Treble and that worked
I had the same problem with my NIB as well. I also noticed that I could barely hear some of the characters though others were a good volume.
As a first time pinball owner it took me a bit to figure out. You should have a second set of keys. Use those to open the top part. The keyhole is above the screen and under the speakers. Once unlocked, the glass in front of the screen can slide up a bit and then come out towards you. I unplugged the noise filter audio jack, cleaned the ends off, and plugged them back in. Then I turned the machine back on and adjusted the treble dial until the static was better. This shows you what the noise filter looks like: http://s4.american-pinball.com/img/support/2021-1/Hot-Wheels--audio-connection-and-settings.pdf
Edit to add: This seems to only temporarily fix the issue. Mid game the static is coming back and the volume is dropping.
This page was printed from https://pinside.com/pinball/forum/topic/sound-feedback-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
