I worked on a Sorcerer for my friend lately. Got everything cleaned up fixed a few issues all was good. Game booted up and played correctly. He turned it on today to play and told me half way through the game the coils stopped working. I told him to check F2 fuse which was blown. Replaced fuse turned it on and he said about 20 seconds into the game he noticed the left sling was locked on and then the fuse blew again. Oh boy he didn’t notice it right away!
So I went to see the game today. Ran coil test with the left sling disconnected and all other coils worked. I replaced the left sling coil with a new coil because it was at 5.0 ohms instead of the 4.2 it should be. Turned the game on and the left sling locked on again.
Now here is the big issue. I took 2 additional known working system 9 MPUs with me. Pulled the original mpu and put in the other mpu with the game roms transferred properly. Now instead of booting up, I get error code 7. Reseated all connectors, made sure all connections were correct and turned on again. Error 7.
So, I disconnect mpu #2 and put in mpu #3 which is also a known working system 9 mpu. Same thing. Error code 7. So I know it can’t just be mpu #2 because mpu #3 does the same thing. Just for good form, I put the original mpu back in. Left sling immediately locks on. And the game will not boot. And now on top of everything, I do not have displays. The displays do not work with any of the MPUs. Display fuse checked and is good.
Not sure what happened or want to do next. Could it be the game roms are bad? Plus no matter which of the 3 MPUs I connect now, I do NOT have any displays.
Help!
Thanks! Ed
