Hello- I have a sorcerer that has a right kicker coil that stays on when in game or in the diagnostic menu. Neither of the kicker switches are touching. I tested the corresponding transistors and they measured ok. The coil stops when I remove ij19. Is there an easy way to diagnose if this is a board or playfield problem? Thanks!
Edit: did more testing, grounding the transistor in attract does make the coil fire, so wouldn't that have to indicate a switch grounding problem? Or could it still be a board problem, such as a logic chip?
