Removing head on Sorcerer,
Just disconnect connectors and remove Four nuts from hinge.
Is this correct?
Is this correct?
Quoted from Madmax541:Removing head on Sorcerer,
Is this correct?
You also need to remove the regular head bolts to fold the head down prior to disconnecting the hinges. Helps to have a rachet extension as the speaker panel does not lift out.
Also disconnect the ground wire that should be attached at the base of the head with a wing nut.
Pretty simple overall.
This page was printed from https://pinside.com/pinball/forum/topic/sorcerer-removing-head and we tried optimising it for printing. Some page elements may have been deliberately hidden.
