(Topic ID: 324346)
Sorcerer not booting
By Hazzy121
1 year ago
#1 1 year ago
I have dead Sorcerer that I am trying to get running for a family member. Game lights up all the GI come on but no Displays. Game doesn’t boot. I do not see any issues with corrosion on the MPU. And it is reading “0” as it is okay when powered on. I threw in a new Power Supply Board I had available just to see if it might be an issue with consistent power. Still no change. I reseated all connections and removed and reseated the Roms. I can see a hint of light in one of the displays.. and now I can get a game sound when I hold the coin door button. Speaker is humming. I replaced the batteries and plan to move them off the board. Any ideas on this? Bad Roms? I am fairly novice but not helpless.
75B5EF73-B0EC-4B0D-AF47-EB624DEEABB2 (resized).jpeg75B5EF73-B0EC-4B0D-AF47-EB624DEEABB2 (resized).jpeg78B87F36-387C-4ABF-AD4A-91D9B6BB9C71 (resized).jpeg78B87F36-387C-4ABF-AD4A-91D9B6BB9C71 (resized).jpegD7BC2B82-420D-4404-8351-97B11D43336C (resized).jpegD7BC2B82-420D-4404-8351-97B11D43336C (resized).jpeg
#2 1 year ago
2 balls in the trough? Is it in attract mode?
#3 1 year ago
Yes. Two Balls in the trough. But I can not tell if I am in attract mode since I don’t have displays. I also find it hard to believe all of the displays would be out. That’s why I switched out the power board..
#4 1 year ago
Quoted from Hazzy121:
My Space Shuttle they were all out, someone hooked up something wrong or something catastrophically failed on the power supply and smoked every single glass.
If you are in attract mode you should have light patterns on the playfield. It doesn't sound like its booting up.
#5 1 year ago
It isn’t in attract mode. Stagnant lights.
#6 1 year ago
Define please.
You have GI but no insert lamps or are the insert lamps locked on?
#7 1 year ago
I have no inserts. Only above playfield lights. Slingshot light. Pop Bumper lights.
#8 1 year ago
MPU isn't booting up, need to start there to find out why.
I only mention this as you are giving conflicting information in first post.
#9 1 year ago
That’s where I am looking for some guidance. If I have a MPU reading “0” and the game won’t boot. What would be the best way to diagnose from there? Roms? Looking for suggestions.
#10 1 year ago
Have access to a eprom burner?
https://pincoder.ca/
#11 1 year ago
Right on! I will try that. Thanks.
#12 1 year ago
Check for at least 3.5 volts DC at pin 24 on the U18 RAM module.
#13 1 year ago
that battery holder looks suspect, look at the left hand side.
as above, check battery voltage, also check fuses.
#14 1 year ago
I am getting 2.3 volts DC at U18.
#15 1 year ago
this might just be good news, it may just need a new battery holder, or better yet do away with the batteries and install a NVRAM
https://www.pinwiki.com/wiki/index.php?title=Williams_System_3_-_7#MPU_Batteries_.26_Memory
#16 1 year ago
Sorcerer is a system 9 game. The regular RAM is soldered in the board.
#17 1 year ago
A methodical approach is generally better than jumping around. Try the Pinwiki suggestions in order: https://www.pinwiki.com/wiki/index.php/Williams_System_9_-_11#MPU_boot_issues
$ 22.50
$ 749.00
Watertown, MA
$ 27.95
$ 36.95
This page was printed from https://pinside.com/pinball/forum/topic/sorcerer-not-booting and we tried optimising it for printing. Some page elements may have been deliberately hidden.
