(Topic ID: 310443)
Soooo, how did a 6803 game MELT an EOS Switch?
By Pinwizkid
2 years ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by metallik
#1 2 years ago
A friend of mine operates a Bally Escape from the Lost World in his arcade. It began blowing the 5 volt solenoid fuse and I traced the issue to a bad EOS switch on the upper left flipper (holding the flipper down would blow the fuse in about 2 seconds). Upon inspection I notice the little plastic standoff between the two outer tabs of the EOS had melted off, causing the switch to not open when the flipper was energized. I have no idea how this happened, but I'm guessing high voltage was flowing through the EOS for quite a while for it to heat up that much. As far as I know the high voltage flows through the lower flippers before getting to the upper flippers, so I was going to double check the eos switches on those, but don't know a tremendous amount on how they operate.
I don't have direct access to the machine but will be checking in on it next week when replacement parts arrive and want to know what else I should check to prevent this from happening again. Any advice appreciated!
#2 2 years ago
EOS was misadjusted and never opened. Fuse didn't blow until after the plastic had melted, further cementing the not-opening problem
2,299
Wichita, KS
$ 18.95
$ 36.95
This page was printed from https://pinside.com/pinball/forum/topic/soooo-how-did-a-6803-game-melt-an-eos-switch and we tried optimising it for printing. Some page elements may have been deliberately hidden.
