(Topic ID: 288152)
Sonic prospector not scoring
By Brewster007
9 months ago
  • 7 posts
  • 2 Pinsiders participating
  • Latest reply 9 months ago by Brewster007
#1 9 months ago
Hi all, I have a sonic prospector pinny that I let a nephew play and later he said it's not working. It was not scoring or no lights up on backboard. I had a play with it and left it. This week I checked it again and it would not reset. I went to score reels and cleaned them and now it resets. I pulled out the jones plugs and cleaned them and got the lights to work .So I can play it ,makes all the sounds but score reels will not move. I tried 2 player but it won't move to 2 player because of no score. I do notice that once started and I run over a scoring function there are a couple of relays humming. I checked all the playfield switches and I am at a loss as to what's going on. Any of you clever guys got any idea?
#2 9 months ago
Quoted from Brewster007:
Exactly what is humming?
#3 9 months ago
Quoted from HowardR:
Hi Howard. The lock coil on the base ( single switch on the right hand bank of coils ) And the 100 and 1000 coils on the back board
#4 9 months ago
The Lock relay holding is normal for most games.
Other relays will overheat and burn up their coils if left activated for more than a minute or two.
Do the 100 and 1000 Point relays lock on for all 4 players?
For any more than that, I'll need to see a high quality scan of the schematic from (for example) Staples ($2) or Kinkos ($6)
#5 9 months ago
Thanks for replying .I mean the 100 and 1000 coils that are separate from the score reels. they are in the top of the back box
#6 9 months ago
You circled 2 relays as being locked on.
#7 9 months ago
I played around with the bumpers and it started scoring but when it went into the middle score retrieval and eject the eject is not working. The coil tests ok so I will look into it further . I think it may need a big clean of contacts.
