(Topic ID: 294262)
Sonic Cherry Bell General Illumination problem
By bonzo71
2 years ago
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by bonzo71
#1 2 years ago
I'm having an issue with the general illumination on the playfiled of my Cherry Bell. After the ball drains and the bonus count scores and around the time the ball count advances, the playfield general illumination lights go out. Note the issue does not impact the feature lamps on the playfield or the pop bumpers. Here is a video of the issue which happens at 00:23, 00:46 and 1.05.
The seems to be related to the top switch on the 2nd score motor cam from the motor. I'm actually able to get the GI to go off by lifting the top switch on that cam. I do not believe this is supposed to happen though.
The GI and feature lamps on the playfield appear to use the same ground braid, so I do not believe it is an issue on the ground side. Any suggestions would be appreciated. I do not have a schematic, but there is one here: https://www.ipdb.org/files/3070/Cherry_Bell_Schematics.pdf
Due to the fragile nature of the jones plugs on this game, a fix using a jumper might be a good idea. I'm just not sure where exactly to put one.
#2 2 years ago
usually if opening a switch in the 24V circuit affects something in the 6V circuit when it's not supposed to, you have a problem with a section of the yellow common power wire not being connected back to the transformer.
as a quick test, jumper from the yellow wire on the transformer to the yellow wire on the GI lamp sockets and see if the GI flashing goes away. If it does, the yellow wire daisy chain is broken someplace. Could be at the plug, but could also be a poor solder joint at any of the places a double yellow wire is connected.
the switch you opened is 2D with yellow wire on the center blade and blue/black wire on the top blade?
#3 2 years ago
Bladwit,
Jumping the GI to the transformer yellow resolved the blinking issue. The schematic refers to the cam as "1", but it is the cam 2nd from the motor and after the index cam the switch that results in the GI going out is at at level "E". The wires appear to be black at the top and Red with a yellow stripe below.
Before I purchased it, the game was stored in a very wet basement with water that was occasionally a few inches deep. Thankfully the prior owner kept it on its legs. The result is corrosion at the jones plugs. I love it though..it is a super fast player and people are drawn to the art work (or offended).
I'll mark this as closed since I have a repair option and an eventual path to hopefully find the break in the yellow wires.
Thank you again for your help!
#4 2 years ago
if you get a chance, please post a pic of your cams/switches from back far enough to see the switches, wires and motor.
sounds like your game doesn't match the schem ... neither of the E switches on the schem diagram should be closed when the score motor is indexed.
oh well, sounds like your on top of it.
if the jones plugs are bad, you can get replacements or change to molex plugs.
#5 2 years ago
Give me a week Brad as I haven't quite finished my re-draw. It looks great. Cheers, Mal
#6 2 years ago
Quoted from Hyperball91:
I'll post some photos tomorrow.
#7 2 years ago
? I think that message was meant for baldtwit, not me, but yeah, a good playfield pic would be nice
#8 2 years ago
20210531_225916[1] (resized).jpg20210531_225916[1] (resized).jpg20210531_230003[1] (resized).jpg20210531_230003[1] (resized).jpg20210531_230031[1] (resized).jpg20210531_230031[1] (resized).jpg20210531_230348[1] (resized).jpg20210531_230348[1] (resized).jpg
This page was printed from https://pinside.com/pinball/forum/topic/sonic-cherry-bell-general-illumination-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
