I’m having 2 issues with my Sonic Butterfly that I having trouble fixing. I’m not sure if they are related or not, but thought I’d mention them together.
1. The 1000 point relay locks during reset and I cannot get it to turn off. When the playfield is detached, the 1000 point relay does not lock. I know that typically indicates a locked switch on the playfield, but I cannot find one. I’ve tried blocking each switch with a post-it, but that does fix the issue. I’ve checked the eos switch on the 1000 reels and they are ok. As I advance the player unit, the issue follows through to each player. I had a bent snow shoe on the player unit, but I fixed it and even tried one from a different(working) game and to eliminate the possibility of the player unit being the issues.
2. When the ball enters the kickout hole in the upper left hand part of the playfield, the bonus unit advances all 10 steps to 100,000. This all happens within ½ turn of the score motor. I believe it should increase once when there are no lit lamps by the kickout.
The front screw on the double bonus relay on the reset bank is missing. The threaded hole that holds the screw is stripped. I’m looking for a replacement, but can’t find the correct size/diameter. I tried a 6-32 screw and the diameter was too large. My plan is to find slightly longer screw and attach a nut to the end. Does anyone know what diameter screw goes into a Williams switch stack (4-40 maybe)? I need one the is 2.5 inches for the nut. Although the screw is missing, The switches on this relay are operating properly. The bonus is 20,000 per step and when the double bonus is activated and the double bonus lamp lights when the relay is activated.
I've been struggling with this for over a month. Any suggestions would be appreciated.
