I've gone through many forms and videos, but they always talked about an entire row or column being out. My issue is that I have 5 out of 8 switches in the same column not working on my Flash. Only the three bumpers consistently work on Switch Matrix column 3. What I find most crazy is these three bumpers are not even wired in order, switches between them don't register. Every now and then though I can get the other 5 to register, but it's very very rare.
I've traced down the green/orange and confirmed a good solder connection at every point. Also the white stripe cable for the rows look good too at each switch.
I took the molex off of the board, pulled out the green/orange wire and tested by attaching the single wire to the board without the molex connector, same issue. I then pulled a different column wire (green/black) and directly attached to the molex pin on the board, allowing me to use different switches in test mode to get the non-working switch numbers to display (so switch 33 would display 17 on test). So this tells me that it's not a board issue, right?
No other switches outside of column 3 have issues.
Another fun fact. If I hold down a switch that isn't working and then trigger a bumper, I get bumper points and the non-registering same column switch points.
Attaching photos of matrix, and manual where I noted which order the green/orange connects to each switch.
Any suggestions would be appreciated! Thanks!
