HI all, I thought it may be fun to get a thread of 'simple tips' going for when working on pins -
there area lot of creative and pragmatic individuals and of course those with much experience who can add tips here -
I will start with a few that were given to me and that I found very useful ...
when working on my playfield underside (either propped on its stand up rod, or turned back to lean against backbox) I was told to lay a towel crosswise over the lower cabinet - this 'tent cover' has caught many a dropped screw or bit that might have been lost in the bowels of the cabinet, and possibly some day cause a short ... I know I know, common sense - but I hadn't even thought of it till the tip was passed
another I am sure most of you already know of / use - to get those hard to reach pesky bulbs out if they are tight ... use a shooter rod tip rubber as a grabber - this one works great!!
and lastly for now - if a piece does fall under my cabinet board where it cannot be seen - and I don't want to unbolt the bottom panel ... I take the schematic, which is typically folded in '6' on a gottlieb at least - I leave it folded in 3 the longways, this acts as a nice bendable 'plank' that I can easily slide under the bottom panel and slide back and forth side ways to explore and see if any bits are under there - and bump them out to where I can get them
anyhow - I am sure many of you have much better 'common sense' tips or ingenious tricks to share so lets hear them pls
cheers, Ron
