Hey all,
I have all new bulbs in the back box of my Big Hurt machine... As you can see, some of them don't light (ignore the larger flashers at the top, they work fine, they were just off at the moment).
The workouts ones are pulling abkut 5.8V AC.... The random ones that are not lighting do NOT show any voltage. I tested the body of the socket against the center pin to test all these voltages.
This is strange to me since they are all in line with each other, pulling voltage from the same source. So, I take it that 'dirty' sockets aren't the issue here, and it has something to do with contact points....
Is this a case where the solder joints that connect the power wires to these specific sockets is bad, since the power, obviously, flows past the socket and feeds the others properly?
Always learning,
Matt!
