(Topic ID: 71647)
Some help needed with Data East Playboy 35th anniversary R31 - R38 resistors
By bobWeir
10 years ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 10 years ago by galaxian
#1 10 years ago
Working on a Playboy 35th anniversary and the whole row (R31-R38) of resistors is getting so hot. If I left the machine on it would probably start on fire. Hopefully someone has come across this problem before. What would cause this? Where should I look next?
Thanks,
Darin
#2 10 years ago
CPU Board
#3 10 years ago
Well, I would check what voltage is supposed to be feeding through those resistors and check to see what actual voltage is going through.
The power supply is prone to needing fixing. I know certain Caps leak and the voltage regulator goes bad too. (I had to rebuild my power supply on mine)
#4 10 years ago
Power supply is probably out of spec. I just replaced mine with a new rotten dog one and its running great now. I did have to replace a 68 ohm resistor on the cpu for the solenoids that was a casualty of a bad power supply.
$ 18.95
$ 27.95
$ 18.95
$ 65.00
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/some-help-needed-with-data-east-playboy-35th-anniversary-r31-r38-resistors and we tried optimising it for printing. Some page elements may have been deliberately hidden.
