Hi All,
For my first pinball purchase I decided to go for a CFTBL which, other than a couple of bulbs needing replacement, seemed to work fine (I never really played that many CFTBLs prior to buying this one so I didn't have a full picture of gameplay).
Recently I discovered the centre lane entry gate switch wasn't triggering consistently as I was rarely registering centre lane shots so I replaced it and via the single switch test it worked consistently. Even so, centre lane shots still weren't registering. After continually testing the centre lane exit switch it seemed that it wouldn't trigger 100% either so tonight I replaced that as well. The bad news is that it still didn't fix the original problem.
With a ball in play I blocked the outlane and proceeded to move the ball around the playfield by hand and then realized that some switches (such as the centre lane entry switch and right ramp entry switch) would cause the flippers to briefly flip. I could repeat this a second time but not a third time and from then on the centre lane shot would then register fine. After a period of time where I would hit bumpers or trigger a popper, centre lane shots stopped registering again...strange!
A previous owner had modded this Creature to light up the pop bumpers so I thought that maybe there was too much power being used. I disconnected those lights (they were wired to a bulb on the General Illumination (GI) 3 line) but even then the problem persisted.
So my problem is that I have no idea what's causing this and where to look next. I'm dreading that the next step is to get a repairer to take a look but run the risk of paying hundreds for no solution as I have a feeling that something like this isn't that common and easy to fix.
Any ideas?
Vas
