Hey guys, N00b here. I have an NBA Fastbreak. Just replaced 4 switches that went bad on me. As soon as I powered it back up, I tested all the new switches I put in, and all tested fine. However, NONE of my solenoid are firing anymore. I ran the Solenoid test, and nothing occurs. It looks like the test is running, but none of my Solenoids are firing. I did the obvious: Checked and replaced the fuses on the driver board, and checked all the connectors under the playfield to make sure they are snugly fit. All looks good on those fronts. What would be next step in troubleshooting what the issue might be? Did I muck something up by putting in these new switches?
Thanks in advance!
