This is indeed a puzzler.
The coils you mentioned come from both the high power side, and the low power side.
As Blake above says, check to see if you are getting power to these coils.
I would normally have suggested that you have a broken wire, not necessarily at these coils, but one link further up that isn't making connection, but this could be two wires broken, disconnecting power to everything downstream. Two problems sounds a little weird, but pinballs can develop lots of problems over time.
Deep dive isn't too hard, here is the manual:
https://www.ipdb.org/files/2684/Bally_1993_Twilight_Zone_Operations_Manual_OCR_searchable.pdf
On page 2 of the PDF it lists the coils and where they plug into the Power Driver board (J107 pins 2 and 3, going to J130 and J127)
It lists the specific transistors that drive the coils, so this should be easy to trace.
Let us know if you've got power to the coils and we'll be able to help you troubleshoot from there.
