(Topic ID: 284198)
Solenoid Question
By Stephan28
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 3 years ago by Stephan28
#1 3 years ago
I’m perplexed. I replaced the knocker solenoid on my Williams Flash machine because the original was burned up and the ground wire (brown/blue) had come off of it.
I’m looking at this solenoid and the schematic on the solenoid just looks wrong. It has the power wires going to the side opposite the diode bar.
Do I have this wired up correctly or do I need to reverse the wires?!!? Most of the other solenoids have the red wires going to the bar side of the diode.
BC29A17C-1FB9-4C5F-B0C6-D7EEBE9A1B86 (resized).jpegBC29A17C-1FB9-4C5F-B0C6-D7EEBE9A1B86 (resized).jpeg
#2 3 years ago
Ignore whatever it says on a replacement coil and check the manual. Your instinct (looking at the other coils) was right. Your wires are reversed. Red wires to the banded side of the diode.
#3 3 years ago
Awesome! Thank you for chiming in. I saw the same diagram that you referred to in your post. I will reverse the wires and carry on. Thanks again!!!
#4 3 years ago
Keep in mind that if your old coil was toast and a wire was disconnected, the driving transistor for that coil may be shorted. After you switch the wires, if you hear the knocker fire when you power up or start a game, shut it off immediately and test the transistor for the knocker.
#5 3 years ago
Quoted from phishrace:
Yep, good call! I sent the boards out for repair and lo and behold solenoid drive transistor #14 was shorted.
Before the reworked boards come back I’ll be sure to swap the wires on that knocker solenoid and hopefully I’ll be good to go.
$ 12.50
RoyGBev Pinball
$ 9.95
$ 170.00
Displays
Digipinball Shop
$ 130.00
KAHR.US Circuits
2,100 (OBO)
Milan, IL
$ 11.00
400 (OBO)
Green Brook Township, NJ
Tools
Pincoder Store
$ 27.95
This page was printed from https://pinside.com/pinball/forum/topic/solenoid-question- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
