So my symptom is that solenoids 01A thru 07A don't fire or hardly fire. This initially points to the A/C relay. I checked continuity through the contacts on this DPDT relay from fuse2 to5J11 (25v side) A is closed and C is open as supposed to be. the same on the 50v side 5J12 A-closed C-open (Although C is not used I can still test). This with the machine off
When I power the game up I get voltage on the C-side and nothing on the A-side. Further more The voltage is 49-50 vdc on the supposed 25vdc ckt and 77vdc on the 50vdc ckt. I can check all of my fuses F1, F2, F3 are all 49 vdc (should be 25vdc) while F4, F5, F6 all have 77vdc voltages. The flippers are fused at F5 & F6 I see 77vdc at those coils as well (and I just rebuilt them).
so I backed up a bit to before the power supplies 25vdc and 50vdc. The two bridge rectifiers that supply the solenoid power (still located on the Aux power bd) I read 31vac and 56vac at terminal 5J8 feeding these rectifiers.
So my first question- does this suggest that the 2 Bridge rectifiers that supply the solenoid power are bad? Chosen suggested in his reply that my power supply was suspect, Are these slightly elevated AC voltages normal?
I still have the problem with the relay coil closing on power up. Testing the transistor Q8 which should control the A/C relay coil appears to be fine. next I pulled the connector on J12 on the CPU (solenoid drivers) suspecting to see A closed at the relay. what followed added more to the puzzle. checking voltages on all 4 poles off of the relay proved that both A and C are lit up 49vdc A & C and 77vdc A&C
How can this happen the relay should be A or B not both.I looked for pinched or shorted wires...
I am scared to even turn the machine on anymore with these voltages in fear of damaging something.
So do I need to rebuild my Aux Power board? is there anything else I should check?
Marco offers a new and improved board for $129 http://www.marcospecialties.com/pinball-parts/D-11813-552
I think I would rather try a rebuild, any other components I should also replace besides the rectifiers and probably the relay while at it?
