Helping a friend with some issues on his new Rolling Stones. When purchased, he played 3 games with no issues. Upon bringing it home, it ran thru the self test once with no issues, but then coils stopped working in test mode and in game play. At this point the only coils that work are:
#8: Saucer
#12: Drop "D"
#13: Drop Reset
#14: Coin lockout
#15: Flipper relay
#16: Saucer drop
I have rebuilt the rectifier and did the recommended mods to the Solenoid board (new headers, ground mods, note it is a Stern SDB-100 rev C) and board tested the individual transistors. Power is ok at all test points. He has also repinned the 0.156 female connectors for both rectifier and SDB (pushed wires in again on the 0.100 IDC connectors). Have verified 43VDC at all coils, appears to be an issue with the ground circuit. Also, the coils fire correctly when the tab of the individual transistors is grounded to the ground braid?
Any thoughts on what to check next? I'm assuming it's either connector to/from the MPU or a bad IC, but looking for specifics on where to look and how to test.
