On my Shaq Attaq I replaced the solenoid for the top upkicker but failed to notice that I had soldered on backwards the two solenoid wires. Hence, the solenoid no longer works after turning power on to the game. The solenoid reads over 15 ohms and the diode reads 0.1 when testing on ohms. The switch for the upper kicker works. The upkicker's fuse located at F24 was blown and subsequently replaced. Last but not least I discovered that the C12 diode on the driver board was blown as shown on the attached photo. Am I correct in assuming that the blown C12 diode is the source of my problem? I see no other blown components on the driver board. All other solenoids are operable.
Thanks in advanced.
