(Topic ID: 257677)
Soldering Slam Switch Closed Gottlieb System 1
By Genieye
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by Tuukka
#1 4 years ago
Hello, I would like to solder the slam switch that is near the ball inside the cabinet. I am still having game just quits issues and want to eliminate these. I took care of the coin door switch which has 2 wires. This inside switch has 3 wires and would like to know how to do it on this switch. Attached is a pic of the switch and wires. There are only 2 switches to worry about correct? Thanks to anyone who can help me out.
#2 4 years ago
Here is a link to Pinwiki about this....
https://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_1#Permanently_Disabling_the_Slam_Switches
Basicly, jumper C2 and you're done.
It's just right of the reset button.
#3 4 years ago
It's better to add the necessary jumper to the MPU, rather than rely on connectivity to the switches.
#4 4 years ago
Quoted from Inkochnito:
Thanks to both of you for responding. I have a Ni-Wumpf CPU. Does that make a difference as the photo looks like the original board. Can I just solder the 2 switch wires together thus closing the circuit? I am wondering whats with the 3 wires in the pic I sent. The coin door one has 2 wires.
#5 4 years ago
Now this a big WTF! I disconnected the slam switch inside where the ball rail and ball is. No wires from the switch in the photo. The game still plays! I thought an open switch made the game quit? I have game quit issues often and am trying to eliminate sources. Big head scratcher.
#6 4 years ago
Quoted from Genieye:
Yes--that link only applies to the original MPU. I'm not sure what is needed on the ni-wumpf board. You may have to contact the manufacturer for a copy of the manual:
http://www.ni-wumpf.com/index.html
#7 4 years ago
The SLAM switch on the coin door is normally closed. If the switch opens it tilts the machine. This can be 'defeated' by soldering the wires together at the switch (always closed now!) or by modding the original cpu (The aftermarket boards probably already have this taken care of, but double check their manuals).
Now, the ball ROLL TILT switch that you have pictured inside the cabinet is normally open. If the front of the machine is lifted enough to allow the trapped/caged ball to roll towards the switch and close it, the game will tilt. There is no sense in messing with this switch because its easier to remove the caged ball (if its even still present). You can disconnect the wires if you wish and the machine will play normally. EDIT: I was wrong, on system 1 the roll tilt is normally closed!
#8 4 years ago
Quoted from gutz:
Thanks for your response. I do think the caged ball works oppositely of how you described. Its supposed to be closed then the ball opens it. Either way I took the switch out completely and the game plays the same. I think I read somewhere that the NI-Wumpf board takes the slam switch out of the equation. It has to be something like that as took all the wires off the switch and she is playing great but it still quits at times, in fact far too often and I am desperately trying to figure that out.
#9 4 years ago
Both the ball roll and coin door switches are normally closed (and wired in series) and cause slam tilt if opened.
Maybe the Ni-Wumph is designed to ignore slam tilts if the switch is already open at power on - but I am not familiar with those boards.
$ 7.50
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/soldering-slam-switch-closed-gottlieb-system-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
