I got my first pin on Saturday and did my first repair on Sunday. I bought a DM from a forum member that was in 100% working condition. One of the LEDs went out about 3 hours after it was set up. With the help of the seller (thanks dmacy!), I traced the issue to a broken wire under the playfield leading to the LED.
With some additional help from dmacy, I was able to solder the wire back where it went and everything is find now. However, apparently my soldering skills suck, or I just don't know what I'm doing.
It is currently working, but it looks terrible and took me forever. I have a Weller WES51, which I think is pretty decent. The wire in question was just a short jumper that I think daisy chained together a few lights. It was soldered to a post with 3 other wires. I turned my iron up to 80 on the dial and stripped the broken wire while I waited for the iron to heat up. I put some flux on the wire and the old solder. I set the wire on top of the old solder, where the other wires were, and sat the iron on top of the wire.
It took forever before the old solder started to melt, but it didn't melt like I thought it should. I messed around with it for awhile and didn't have much luck. I tried adding solder to it, but the new solder just formed a ball and sat on top of the wire.
I ended up getting it attached, but it isn't the greatest job. I've watched a few YouTube videos on soldering, but everyone is using brand new wire. Did my issues have something to do with it being old solder, or was I doing something wrong?
It got soldered to the post right below my finger in the picture. Unfortunately, I didn't take an after picture.
Also, are there some other things I should have in my "toolbox"? Dave (the seller) suggested magnetic nut drivers and a good soldering iron. Is there anything else I should invest in right now?
