(Topic ID: 144769)
Soldering coils
By PjM
  • 13 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by PjM
#1 3 years ago
Does it matter wire location when re-image.jpegimage.jpegsoldering coils ?
#2 3 years ago
Yes.
#3 3 years ago
How can you tell? Power/return?
#4 3 years ago
Quoted from PjM:
Schematic, manual.
LTG : )™
#5 3 years ago
Good idea, too bad I don't understand it but I will learn how to read it correctly quick and in a hurry!
#6 3 years ago
You didn't say what pin your working on, but in pic 1 if it was wired correctly than the grey/yellow wire is the power becuase it it connected to the terminal with two windings.
In pic 2 the purple/orange is the power wire because there is two of them and they are thicker then the ground wire.
#7 3 years ago
I am doing a TZ. Around 16 coils in all. The pics were just reference. I understand the wires. I am not sure if it mattered on the coil what tab to solder on - right, left or middle or as long as there is one on each.
#8 3 years ago
If the coil needs a diode then it does matter. The power wire is always on the side with the diode band. If the diodes are board mounted, then the wires can go on either direction.
#9 3 years ago
Quoted from PjM:
The flippercoils to help you with the first 4.
#10 3 years ago
Quoted from PjM:
I am doing a TZ.
Flipper coils it matters. Other coils don't have a diode on them so it doesn't matter.
LTG : )™
#11 3 years ago
Thank you very much all of you. This helps me considerably.
#12 3 years ago
BTW, use clip on heatsinks when soldering wire connections and particularly coils in general.
Clean the lug holes and get a good wrap hook with the wires through the holes.
It prevents damage to the windings, lugs, and diodes and makes soldering faster and easier.
Wondering why a coil locks on, will not hold power, does not work or burning up a new coil diodes will make you upset and you will have to do work all over again...
#13 3 years ago
Thanks, I will make sure I do this.
KAHR.US Circuits
$ 14.95
7,000
Madison, AL
$ 90.00
Lighting - Under Cabinet
