Conclusion, for the issue with the right kick out hole, my bad, I made a bad crimp, I crimped it too tightly and the wire frayed.
However the same issue with drop target reset solenoid not having enough power.
So i purchased a new ni wumpt driver bd. Installed it and now drop target reset works. So if anyone has this board with Fairchild or 'On ' semiconductor transistors and is experiencing same issue with drop target bank I would suspect the board. Pictures of faulty board attached.
PS.
new driver bd uses transistors from different manufacturer.
