Well, I spent about 6 hours last night working on Solar Fire. Almost every issue on it is fixed now. I still have one drop target that when running through the test mode will drop and raise perfectly, but in game, it won't drop unless you literally throw the ball at it as hard as possible. Any ideas on that? Also, I don't have a manual for it, but I have deduced that the 3-24 led code i'm getting after the test is a switch that's stuck open or closed. If anybody has the manual and knows what switch that is, i'd be grateful to know
