Hello, this is my 6th EM machine and I've never had any serious problems finding issues since my first one I learned on. This is by far the cleanest machine I've worked on. I've been through it all and cleaned every contact in the machine.
Issue is that the machine doesn't run a start up sequence very well. I've tried what I've read in all the posts prior with activating the startup sequence. DX, S, U, 2B and AX all look perfectly aligned and no contact issues...
Q game relay releases when start button/replay button is pushed.
AX is not released after S relay runs the Motor, however motor doesn't stop unless I manually release AX.
One big thing, I can't for the life of me get the ball release coil to kick the ball out. The contact will release the targets and the players do switch with the player contact switch is rolled over.
Major issue I can't see why it's happening. - When I roll over the contacts on the ball entry it won't disengage the one light and switch between the two entries. Stays on the one single one and the roll over contacts seem correct.
I've tried unplugging the wire harness from the backglass and the door to test.... Still same situation.
Any suggestions would be welcomed. The relays seems to all fire a 5v battery a bit, other way I guess I start taking them off and testing them with an ohm meter.
Thank you.
