(Topic ID: 184199)
Solar City does not reset
By ChilePin
2 years ago
  • 13 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by Darcy
#1 2 years ago
Hi, im fixing a Solar City that dont reset. After pushing the replay button, start relay, hold relay and AX relay puls in and the motor start running but score reels do not reset. What could be? The player unit dont move.
If I manually move few steps the player unit it resets the thousands but the motor keep running.
thanks
#2 2 years ago
From the Manual. Operating Instructions. Just the top 4 steps that may apply to your rest problem.
1. Insert coin or push replay button actuates 'S Relay'.
2. S Relay will lock in through motor switch 2B.
3. S Relay starts the motor running.
4. AX Relay actuates through switches on DX and S Relays. Q Relay will de energize when AX Relay operates.
5. When AX Relay is actuated the score units and player unit reset sequence. The 1st player score units reset to zero through the P3 switch stack on the player unit and motor switch 1A. When these units reach zero the player unit steps once.
If you manually pre-set all of the score reels to zero, will the game continue to re-set?
#3 2 years ago
I would follow what Darcy said, but is your player unit clean? Sounds like you moving it helped it get in tune for resetting a score reel. Since it's only one of the bunch though (even those they reset separately at times) it is likely elsewhere.
#4 2 years ago
Hi, thanks Darcy and Otaku. My player unit its clean and if I set all score reels to zero the motor just keep running, the problem is not there. But trying to figure out why the player unit dont move looking for reset, I touched and cleaned again the P relay (player unit relay) and voila! the game resets properly now. I dont have the squematics to see if the P relay must be NC to the player unit can move.
But, the problem I have now is that the game plays always in ball 1, no matter how many balls drains.
#5 2 years ago
Quoted from ChilePin:
The 'P Relay' is the 'Add Player Unit'.
#6 2 years ago
To continue with re-set,
5. The 2nd player score units reset through the P4 switch stack on the player unit, and motor switch 1A. When these units reach zero the player unit steps until switch P5B opens..
6. When P5A on the player unit closes, 'AX' and 'BX' relays reset through motor 4C and switches on 'DX' and 'R' relay. Reset cycle should be complete.
That is a few more items to inspect.
#7 2 years ago
Thanks, the reset issue is solved.
But do you know why my game is stuck in player one ball one? what makes the game go to ball 2, 3, 4, 5, thanks.
#8 2 years ago
Check the 'DX' Relay, it is the First Ball Relay.
Check the Trough Switch is it closing when the ball rolls over it? The trough switch is normally open, clean it, adjust it, if needed.
The Player Unit controls the ball count, along with the lights on the backglass.
#9 2 years ago
P Relay has a normally open switch. On the Green-White wire.
#10 2 years ago
Thanks Darcy, the game reset ok now. But its stay in ball one and only kick the ball from the outhole one time. I can play ball one, but at the end it didnt count the bonus and stays there. Nothing happens after first ball.
Heres a video:
#11 2 years ago
Gottlieb calls the out hole, 'Ball Return Kicker'. 'O Relay' is for the ball return.
When the ball lands in the Ball Return hole it closes a switch which is under the playfield. When that switch is activated it starts the 'DX Relay', then the ball is held there until the 15th position is closed on the Bonus Unit. Until the Bonus Unit is completed its stepping, the game will not activate the Ball Return Kicker.
Check the switch, DX Relay, and Bonus Unit Stepper, in your video I could not hear the Bonus Stepper moving. The Bonus Unit is attached to the underside of the playfield.
#12 2 years ago
Hi, I re checked the DX relay and now the bonus are counted and the ball popped to the outlane, but the game its still on Ball number 1.
The under arch switch is making contact, but the player unit doesn't move.
#13 2 years ago
Is there a chance that the Player Unit is stuck, wire broken off, coil wire broken off. Can you move the unit to the next step, next ball, by hand? Switches on the Player Unit, out of adjustment? (open instead of closed?).
$ 209.99
$ 40.00
$ 12.99
$ 29.95
Little Shop Of Games
$ 29.99
$ 26.95
$ 99.99
$ 999.00
Hardware
Bright Lights Pinball
$ 29.99
Lee's Parts
CzTV Mods
$ 45.00
The MOD Couple
Flip N Out Pinball
$ 44.95
PinBoss Mods
$ 69.99
$ 99.99
$ 48.00
$ 130.00
Rods Mods
$ 22.00
$ 19.99
