Quoted from Joydivision:If you don't get a sweep with a new ball the very first time the target set is dropped down, you don't get the 50k sweep award for any sweep achieved during that ball.
ok, here are the results of the testing I did over the weekend at a friend's house I was visiting:
He didn't use the 50k sweep thing so we turned it on, and indeed, has to be the first drop or you always have to sweep to get it. Suspect somehow the flag for sweeping is not getting reset properly and will look into it (I managed to find the archived source code for the current 07D revision and will move to rev8 when fixed to differentiate)
Could not duplicate the match bug. Played 4 player game, had one of the players specifically have the same match as the hstd and the other players didn't. Only matched for the one player.
Couldn't duplicate the hstd bug, nor tell what the sound for the 3 bank 'should' be (were not able to swap roms back to stock).
He has a different issue very sporadically, where there's no game over sound at bootup.. This might have something to do with sound register ram and what the game was doing when it was turned off. (Stern games store the sound registers in nvram and earlier games Meteor, Galaxy, and Ali have issue with sounds at bootup in their first ball if they aren't cleared.)
I will check to see if the QS software is doing something screwy like earlier mpu200 games with the hstd award as they had a bug there as well, but the hstd had to be less than the first replay level, then it would set the hstd at the replay level.
Re: the spinner counter storage, It looks like I split the spinner left/right storage somehow which requires it being the way it is. What that way is I'm not entirely sure but I might be able to rewrite it to another way, but there's likely a limit on rom space to add more 'stuff'.
I'm hopeful that the sweep thing can be solved relatively easily. I suspect I only reset the flag sweep uses at ball launch vs. on bank reset, which normally, I'd leave the bank reset routines as stock, but I must have separated it out (if I added the 'switch saver' type stuff I normally do now to it, that's likely it right there)
Joydivision can you possibly put stock roms back in and demonstrate the sounds you hear on the 3 bank reset vs. the 07d roms? The owner of the game didn't think there was a difference, but he tested the new roms a long time ago, put the game in storage, and only recent has had it back out.
We also did not notice anything about the inlane spinner sound being different, so if you can film that as well for comparison.
