Quoted from adol75:Just discovering the Valentine, I've been looking for a reliable one for a while, reliable as in that rings at the right time but doesn't ring all the time for no reasons. It's not cheap, but probably worth it.
How good is it ?
It's no joke. I've had plenty of the higher end Passport's etc. but the Valentine 1 especially with the new technology is great. Buy the V1 connection and adjust your bands for your areas and avoid extra false's. You can even program out local false traps by GPS locations as well.
Quoted from mcclad:I have no problem with someone who wants to go slow. Just not in the passing lane. That is what the right hand lane is for. The left is not an "I want to casually drive at 56 MPH in this lane for about 13 miles or so." lane. Especially when they are perfectly matching the speed of the driver in the middle and right lane. They you get behind a rolling wall that effectively blocks off everyone who wants to get around the jerk on the left. I love how they sometimes ignore the horn or the high beams instead of just moving over to the right. I wish that I could build a realistic looking rocket launcher and stick it out the window aimed at their car to see if that would make them move over. Honk Honk! That's it. Look in your rear view mirror jackass. Do I have your attention now? Move the F*** over.
Agreed. On the other hand, if I'm doing 76 and passing a guy doing 72, and you speed up on my bumper because you're doing 90 and then start flashing your headlights or lay on the horn because you had to tap the brakes, I'm going to be annoyed. And will probably take my time finishing my pass, because fuck that. In other words, the passing lane is for passing and should be used as such, but if you assume the passing lane is the "I never have to slow down" lane, you're bound to be disappointed.
Quoted from fosaisu:Agreed. On the other hand, if I'm doing 76 and passing a guy doing 72, and you speed up on my bumper because you're doing 90 and then start flashing your headlights or lay on the horn because you had to tap the brakes, I'm going to be annoyed. And will probably take my time finishing my pass, because fuck that. In other words, the passing lane is for passing and should be used as such, but if you assume the passing lane is the "I never have to slow down" lane, you're bound to be disappointed.
Amen!!!
Agreed.
I totally agree with your statement. I could give a shit if you are going 1 mph over. Go for it. Take your time, just pass and move over in a reasonable amount of time. I also don't expect someone to jump in the first small gap to move over either...I don't.
It's worse for me when cars approach me coming up from the rear (usually me driving at 79 on cc, but passing on the left occasionally). I move over and then they match my speed in my blind spot. Without dropping cruise or accelerating I eventually get boxed in. It's easy to go fast with someone leading the way.
Waze. The only time it doesn't show me where a cop is is when I'm the first to see him. It's gold. We'll see how long that lasts, though...
Quoted from tamoore:Waze. The only time it doesn't show me where a cop is is when I'm the first to see him. It's gold. We'll see how long that lasts, though...
Unfortunately WAZE handles the important part - navigation - terribly. Hope you like being told your exit is coming up as you speed right past it!
Has anyone tried that ? : https://www.stealthveil.com/
They say it's a coat layer to put on the license plate and front lights, where the Lidar is sighted at, that will absorb the laser beam. Since it's passive and invisible, it should lower the odds to get caught for the FCC ban on jamming systems.
But that's a lot of "Should" so before spending 100$, I'm wondering if anyone tried it !
Quoted from adol75:Has anyone tried that ? : https://www.stealthveil.com/
ever try just not driving like an ass?
Quoted from Marvin:ever try just not driving like an ass?
Yep and I fell asleep and almost killed someone
(ps : It’s a joke, no need to double jump me)
If it worked that well why wouldn't they just make stealth planes out of it instead of spending all that money on angles and creating new absorbent materials..... Obviously a little tongue and cheek but I am always leery of those coating type of things that claim miraculous results. It would be pretty incredible indeed if it could truly absorb 100% of a light beam.
Quoted from Jarbyjibbo:If it worked that well why wouldn't they just make stealth planes out of it instead of spending all that money on angles and creating new absorbent materials..... Obviously a little tongue and cheek but I am always leery of those coating type of things that claim miraculous results. It would be pretty incredible indeed if it could truly absorb 100% of a light beam.
I'm not saying these coatings work but infrared light is a whole lot different that an active radar signal.
I doubt it absorbs 100% of the light beam, probably more a portion of it, maybe enough to be effective at a long range, probably less the close you get to the source. So it might help a bit for these long straight desert roads, but the hidden cop right after a curve will probably still cost you a bill.
Going over the speed limit is "driving like an ass" in your opinion?
I would have to disagree, there are soooooo many other things that would qualify as driving like an ass
I believe Iowa had 100 mph speed limits in the '50's and early '60's. This was before consumer tires and suspensions were so advanced.
I don't think the Hawkeye State wanted people driving like asses.....
Quoted from northerndude:Going over the speed limit is "driving like an ass" in your opinion?
On a public road, while wanting people who are going the legal speed are "in your way" yes.
Quoted from adol75:I doubt it absorbs 100% of the light beam, probably more a portion of it, maybe enough to be effective at a long range, probably less the close you get to the source. So it might help a bit for these long straight desert roads, but the hidden cop right after a curve will probably still cost you a bill.
I've read that bright lights can be effective at preventing a good read, but I don't think that's the case with the newest tech. Here's a pretty good read on the subject.
Have you received your Super Speeder love letter yet? More important, has your insurance COmpaNy CONtacted you yet?
A thousand bucks unreported fine and $5-800 for a Lawyer would have been the better choice here.
This guy gets it.
OP: Your move was moronic, and you got caught. Sucks to be you.
Been driving that route for years. Anything around Tifton in GA is bad news. No more than 4 mph over the speed limit or they will get you pretty good. It's going to make you think a bit about speeding now, which is the point of the fine. It does suck.
My wife always gives me crap for the time I got a speeding ticket on the AutoBahn in Germany. How can you get a speeding ticket on a road without a speed limit! It appears that limitless speed is only in some areas and speed traps are still set up a couple miles outside of the drops in speed to give you time to slow down from going 120-140mph back down to 60mph.
Quoted from Furio:My wife always gives me crap for the time I got a speeding ticket on the AutoBahn in Germany.
Isn't that what wives are for - to keeping bringing up all of our past mistakes?
And going more than thirty miles an hour over the posted imit should get the driver auto-banned.
Quoted from zr11990:How do you get a ticket for speeding on the autobahn?
Quoted from Furio:How can you get a speeding ticket on a road without a speed limit! It appears that limitless speed is only in some areas and speed traps are still set up a couple miles outside of the drops in speed to give you time to slow down from going 120-140mph back down to 60mph.
I try for the humor in equating the Autobahn with being auto-banned for speeding and I get down-voted for it.
Sorry guys. I'll work on my sense of humor and try harder next time.
Quoted from littlecammi:I try for the humor in equating the Autobahn with being auto-banned for speeding and I get down-voted for it.
Ill go through and upvote your posts to make up for the down vote.
Quoted from Toasterdog:I have a V1, but it was at Valentine getting serviced. It's my second actually (1st was stolen)
I just sold my V1 after owning several versions over the past 20 years, replaced it with a Uniden R7... pricey, but man what an upgrade from the V1. And I think you'll agree, after getting a ticket like this, that Radar detectors pay for themselves. At least mine have.
Between this and Waze, you should be well protected.
Quoted from zr11990:What is Waze?
Download the app. It's users contributing to advise of traffic conditions and radar sites. Works better than gps to get you to your destination fast.
Quoted from MrBally:Not just Radar, Laser and police hising in general. Also red light cameras.
And hazards in and around the road, including potholes in the highway (didn't know that last one until I got a large pothole ahead alert coming back from GSPF last weekend). The police warnings in advance are gold. BUT, you pretty much HAVE to have your phone plugged in to use it as it will suck your battery dry FAST due to the constant network usage and 3D rendering of the road and points on the road.
Quoted from PinMonk:And hazards in and around the road, including potholes in the highway (didn't know that last one until I got a large pothole ahead alert coming back from GSPF last weekend). The police warnings in advance are gold. BUT, you pretty much HAVE to have your phone plugged in to use it as it will suck your battery dry FAST due to the constant network usage and 3D rendering of the road and points on the road.
I just downloaded Waze based on the numerous recommendations and agree that I do prefer it to other maps apps I have used before. The alerts are nice and the only thing that is a little annoying is the ads when your vehicle stops. I've only been using it for about a week but I have been pleased so far (it actually made me buy a windshield mount for my car).
They have speed zones.
Quoted from gliebig:So people will type in their phone while driving that they saw a pothole? Sounds safe.
Voice commands are available. Like a Tesla.
Everyone isn't driving alone. Plus, it's like two taps. All icons.
This page was printed from https://pinside.com/pinball/forum/topic/so-i-got-a-1132-speeding-ticket-in-georgia/page/7 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
