(Topic ID: 97559)
So I bought the .156 housing for the connectors...
By nighttaco
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 4 years ago by schudel5
#1 4 years ago
Didn't realize they came empty, what connectors do I buy to go in the housing? It's for a world cup soccer 11 pin GI molex connector that burnt. Any help appreciated, thanks!
#2 4 years ago
https://www.greatplainselectronics.com/products.asp?cat=80 scroll down and get the trifurcoin ones.
And don't just replace the connector, you need to replace the pins on the board too.
Ed at Great Plains has all you need in parts and tools.
LTG : )™
#3 4 years ago
You will need a crimper tool. I use the $14.00 ones from Great Plains. They work just fine...
https://www.greatplainselectronics.com/products.asp?cat=138
#4 4 years ago
Quoted from nighttaco:
they come empty because different wire gauges need different connectors.
#5 4 years ago
Quoted from vid1900:
Good point... There are basically 2 different sizes based on wire size. I keep a healthy supply of both.
#6 4 years ago
Thanks for all the help guys! first time repinning one of these....
#7 4 years ago
Depending on the connector housings you purchased, you may not want trifurcon pins. If you look up the Molex connector part number it should tell you what series of Molex terminals/pins it works with. I'm speaking from experience Early on I made the mistake of using trifurcon .156 pins in a Molex housing they weren't made for and they fit SUPER TIGHT onto the header pins on a Williams Sys7 board. They did not go on easily and definitely did not come off without a fight! And that was with the board out of the machine (at the bench) where I had access from all angles.
You'll probably be fine with the trifurcon, but just so you know there are .156 connector housings that won't work with them properly.
http://www.pinitech.com - "Pinball Inspired Technology"
Kits, upgrades and test equipment for pinball machines
#8 4 years ago
Alright, so just to make sure I get the right connector for the board as suggested and replace that too... is it the CP100-11-LR Connector, 0.1" Plug, 11 Pin?
#9 4 years ago
No. You need .156, not .1, size.
Get this one, cut to size :
https://www.greatplainselectronics.com/proddetail.asp?prod=26-48-1245
LTG : )™
#10 4 years ago
Awesome, thanks again!
#11 4 years ago
And make sure you put the connectors in the housing the right way (there is a locking barb that locks onto a slot) otherwise you'll have to damage the connector to get it out and start all over cutting, stripping and reconnecting.
PinSound
$ 69.95
$ 50.00
San Diego, CA
$ 8.50
Bright Lights Pinball
$ 47.00
$ 66.95
Flashinstinct
Fullerton, CA
$ 129.00
LED OCD
$ 17.50
Playfield - Plastics
$ 229.99
$ 11.95
Gweem's Mods
PCB Emporium
Aliso Viejo, CA
KAHR.US Circuits
$ 225.00
Professor Pinball
