Quoted from Dawson:well she is not fixed yet... I have discovered 14 errors 5 switches are not working ... the top center and bottom targets , and the miraclous save and the left in-lane.. all out ..
I'll try and look up the switch matrix but a few questions first.
Since you had this PM has everything been working OK all along or have you had issues with it since you got it?
The most common cause of bad switches is "Broken Wires", plain and simple. I have repaired over a dozen broken wires in about a two year time, although the last one I repaired was about 6 months ago.
Sometimes a wire is daisy chained from one switch terminal to the next and if a wire breaks at one switch it takes out several more. You need to look at each switch 's terminals and see if any wires are broken off or poorly soldered. You can also ohm out , point to point.
Quoted from Dawson:I have also noticed a “leak” the machine pulses and all the back glass lights are on but very dim and pulse like a heartbeat , I have also noticed that a-lot of the lights in the BB are blackened chrome like ?
well my PM pulses and dims and brightens and there is no problem as far as I can tell.
Are the Lamps always dim?
Can you post a video of your Head doing this?
