(Topic ID: 72365)
SmartDmd : DMD interface with colors, upscaling, network and more !
By oga83
10 years ago
  • 613 posts
  • 123 Pinsiders participating
  • Latest reply 2 years ago by Cadrion
  • Topic is favorited by 153 Pinsiders
There are 613 posts in this topic. You are on page 6 of 13.
#251 9 years ago
Quoted from Erik:
Data East/Sega Version 3 support?
Only downside to colorizing those is you're limited to a 4 color palette (across all frames, not per frame). Still, I think it would still be cool to colorize apollo 13.
#252 9 years ago
Here's a better example of what the upscaling looks like:
#253 9 years ago
Quoted from PinballMikeD:
Looks almost exactly how PinMame handles 'upscaling'.
#254 9 years ago
Quoted from toyotaboy:
Only downside to colorizing those is you're limited to a 4 color palette (across all frames, not per frame). Still, I think it would still be cool to colorize Apollo 13.
I thought the palette swapping was performed frame by frame when using an interface like PinballMikeD sells. Maybe I misunderstood the product
#255 9 years ago
Quoted from Erik:
According to the creator, Pinball browser cannot modify Whitestar firmware, which means a global pallette
#256 9 years ago
This is correct, for now anyway
#257 9 years ago
#258 9 years ago
I've recently received quite a few email inquiries regarding upscaling and how it relates to SmartDmd.
To clarify, Pinball Browser is already equipped with ability to replace each dot with up to 64 individual pixels, so upscaling isn't an issue. We chose to offer upscaling at 2x because we thought it looked better, as it’s less cartoony. I didn't really think people would like the look of 16x upscaling, but I guess I was wrong
Anyway, as SmartDMD is highly configurable (especially for dot shape configuration and upscaling in particular), I’ll add 16x upscaling in the next release. The programming for this is already done, as it’s essentially the same as 2x upscaling. I just need to unlock the feature in the next release or Pinball Browser, which should be available in a few days.
Here is what it looks like with AC/DC (PinballMikeD colorization) :
#259 9 years ago
Upscaling wars!
I dunno man, I'm down to try any kind of upscaling or tweaking or whatever, see what I think after giving it a try myself. But at the end of the day I think I mostly just dig the original dots, just with color.
That top image looks like a muppet.
Dr-Teeth-in-The-Muppets-Bohemian-Rhapsody.pngDr-Teeth-in-The-Muppets-Bohemian-Rhapsody.png
#260 9 years ago
For the record, I'm digging what I see with the 2x; and not so much the 14x. It is easy to parse the 2x as "pixels" with antialiasing, but the smooth-ish irregularly shaped lines with the diagonals just doesn't look good and tends (in my mind) to simply be "drawn wrong" (versus low res).
All that said, experimentation is good.
#261 9 years ago
Quoted from Aurich:
Muppet mode is an additional feature we're working on
Here's what the actual image looks like:
16x Upscaling
2x Upscaling
Standard Dots (My personal favorite for this particular game)
Here's a grid look for fun
#262 9 years ago
Has anyone tried using a pi A+ board for this? I see someone tried a B+ any reason there would be an issue?
Anyone tried getting power from a DE system 3 board like they do with the dmd extender?
Looking to order 2 of these and trying to decide between waiting for the dmd extender to get back in stock or go with this.
#263 9 years ago
Quoted from dung:
I have tested it on the A, B and B+.
As the B+ is a replacement for the B, it should alwso work on the A+ that replaced the A.
#264 9 years ago
Thought as much, but it was worth asking. The dmd extender has been out of stock due to it not being compatible with the + boards.
#265 9 years ago
Has anyone done any sort of tutorial on how to use Pinball Browser / SmartDMD properly?
I have been playing with it for BDK but I cant quite get my head around how to do it easily.
eg one set of transitions may have 50 frames, Is there any way to copy sections of frame 1 into frame2, into frame 3 etc.
Also after I get through a couple of test frames then it no longer seems to save the new colour info.
I am sure I may eventually work it out, or keep emailing Oga but would love to see some short tutorial videos by some people that have already done the hard yards.
The above example is not the only thing I am struggling with, and I think its a great tool for doing something special to those titles that are not necessarily going to be colourized anytime soon.
#266 9 years ago
So no dice here. I am trying to set this up for two different machines. Both machines I am getting the same issue. LCD turns on and displays the raspberry pi logo in the upper corner. That's it. Anyone have any suggestions?
#267 9 years ago
Quoted from raysco:
There is a fill all button. It replaces one set color you chose with another color you chose across the frame. Then there is a fill just like in ms paint deluxe paint or what have you. Once you understand how it works its just tedious work after that
#268 9 years ago
Quoted from dung:
Are you trying to set up a smartdmd in a acdc? more details please.
#269 9 years ago
I had an issue with certain SD cards. I had a couple laying around and neither would boot properly. I bought a new Lexar 8GB and those worked fine
Quoted from dung:
#270 9 years ago
Is anybody selling an extra dmd extender? Really need one to finish up a restore before TPF.
#271 9 years ago
Quoted from Monster_Bash:
Tried the earlier image and switched usb cables. I was not getting a green led meaning it wasn't booting. Currently putting the latest back on to see if it is the issue.
*Confirmed the latest image does not work on either of my raspberry pi a+ boards*
Also I did not get a license with either of my smart dmds? Do I also have to pay for the license on top of the cost of the boards?
#272 9 years ago
Quoted from dung:
Raspberry models A and B were very sensitive to the SD card (especially when a micro-SD adaptor was used), but AFAIK, it's not the case anymore with A+/B+ that use a micro-SD card.
I know some old Raspberry won't boot with the new image (that was made for the B+) and that's why the previous one is still available.
I have to get an A+ to see why you can't boot.
Quoted from dung:
Of course not ! You just have to send me your Raspbery serial number (that is displayed when SmartDmd starts).
#273 9 years ago
Quoted from Coyote:
Looks alot like super eagle filter on mame
#274 9 years ago
Quoted from Aurich:
Muppets pinball!!!
#275 9 years ago
Quoted from raysco:
I'm currently putting together a tips guide (in ms word format) in my spare time.
if anyone wants a copy of what I've got complete (so far), just shoot me a pm with your email address
#276 9 years ago
Please update the FAQ. It says use a 4GB sd card so I bought two. Problem is that they come out to 3.68GB and the image is 3.7GB...
#277 9 years ago
Quoted from dung:
It depends on the SD card : some are slightly smaller than others.
I'll try to shrinken the next images before uploading them.
(in the meantime, if you're familiar with linux, you can bypass this issue : use dd instead of diskimager, but it's more tricky).
-1
#278 9 years ago
Quoted from oga83:
I figure why deal with the hassle? The cost difference is very minor and chances are the images could get bigger in future releases. Makes more sense to just set the faq to say 8GB and cover all the bases imo.
#279 9 years ago
SmartDmd supports 2 different colorization modes :
- "In-Frame" mode : the color information is embedded into the frame. For some frames, this can lead to 8 missing pixels in the upper-left corner (but there are ways to minimize this)
- "Side-Channel" mode : the color information is transmitted from the pinball machine to SmartDmd in a separate cable.
There are 2 possibilities for this mode : a GPIO cable (15 palettes max) or a Serial cable (255 palettes max).
(More info about these modes here)
For the ones who want to build a "side-channel" cable, make sure that your game is compatible with the Pinball Browser Communication Patch (try to load the comm117.hex patch), and choose either the GPIO or the Serial one (only one is needed, not both !)
Once the cable is made, use Pinball Browser to colorize your game
Don't forget to select "side-channel" in the SmartDmd tab (before assigning palettes to your frames) and to configure SmartDmd accordingly (select "side-channel" in the SmartDmd configurator).
Side-Channel (GPIO) :
With this cable, you can have 15 palettes.
You need 4 wires between the Sam-Cpu-Board-J1 connector and the Raspberry B+ J8 connector :
Pinball -> Raspberry
J1-6 -> J8-37
J1-7 -> J8-35
J1-8 -> J8-33
J1-9 -> J8-31
Here is a photo of the connections :
The Raspberry B+ is on the left (with a SmartDmd adaptor installed) and the pinball machine is on the right.
On the cpu-board, I have crimped the wires directly on the connector
On the Raspberry, I have used the following connectors :
http://fr.rs-online.com/web/p/connecteurs-idc/5067036/?searchTerm=506-7036
but any similar connector will work.
Side-Channel (Serial) :
With this cable, you can have 255 palettes.
You need to connect the Raspberry to a TTL-RS232 adaptor, like this one : http://www.amazon.fr/dp/B00G23NUNI/ref=pe_386181_37038081_pe_205631_30430471_3p_M3T1_dp_1
The TTL-RS232 is then connected to the Sam-Cpu-Board-J4 DB9 connector with a straight DB9 cable.
Raspberry -> TTL-RS232 adaptor
Rpi-4: TTL-RS232-VCC
Rpi-6: TTL-RS232-GND
Rpi-8: TTL-RS232-TXD
Rpi-10: TTL-RS232-RXD
Here is a photo of the connections between the Raspberry and the TTL-RS232 adaptor. I have taken the Raspberry signals on the SmartDmd adaptor :
#280 9 years ago
The last version of SmartDmd has several display modes.
Each of these modes can be used for the whole game or for a single color palette.
If you want to use "Anti-Aliasing" for videos and "Upscaling 16x" everywhere else, you can
Standard mode :
You can adjust the shape and size of your dots :
These are just examples and you can define each pixel of the dot
For example, with "Cross 8x8" dots, the result will look like :
You can also use one of the upscaling modes :
2x :
16x :
Or the anti-aliasing mode :
IMO, the anti-aliasing mode is the best one for videos like the ones in AC/DC :
#281 9 years ago
I know some people like it and I'm glad you have it for them but I do not like 16x. The graphics were designed to display on large dots with gaps between them. Some things just don't tranlate well when filling in those gaps. I'm very glad you give the option to display how your like it. It should keep everyone happy.
3 weeks later
#282 8 years ago
Scrolled through this post a few times and I se there is support for Data East but........was someone able to figure out how to make it run for the 128x16 DE displays?? I searched a few times and couldn't find it mentioned one way or the other......fingers crossed...
#283 8 years ago
Quoted from agodfrey:
Try to modify the following lines in smartdmd.txt (do not use notepad.exe; use wordpad.exe instead) :
dmd_type=1
dmd_width=128
dmd_height=16
#284 8 years ago
FYI - for people that are interested, I've started an additional thread to discuss SmartDMD and how it works. As promised, I'll provide detailed tutorials on how PB and SmartDMD can be used to colorize Stern SAM machines. I'll also cover how to build a SDMD kit for those that want to build their own. I'll coordinate with Oga to ensure I present information correctly and keep track of new features as they are implemented. Here's the link:
https://pinside.com/pinball/forum/topic/smartdmd-everything-you-need-to-know
I know we have several SmartDMD threads already, but I hope to provide a step-by-step users guide that will unveil the mystery behind how the software works and give people the tools they need to start colorizing their own games.
#285 8 years ago
What are the advantages/disadvantages of using the SmartDMD board over the DMD extender? If it has already been covered can you point me in the right direction. SmartDMD/DMD extender is the way I want to go, just seeing which is best.
#286 8 years ago
DMD Extender is a great product, so you can't go wrong either way. What game are you looking to install a kit in?
My advise is that you checkout the DMD Extender thread Crash created and see which one you like best.
#287 8 years ago
Cool. Yeah I am looking at putting it into a Johnny mnemonic . I just couldn't see which way to go. Both look great and just trying to see if there was a better W/B or...something....I'll investigate further.
#288 8 years ago
If anyone is looking for one of these I have an unused one, correct lcd controller, raspberry pi a+, 8gb microsd, basically everything except the lcd screen. Accidentally broke the lcd putting it in JP and then sold the machine.
#289 8 years ago
Can anyone recommend a place to buy raspberry pi's that overclock correctly? Want to upgrade the one in my batman. My Raspberry PI A+ has crappy ram which will not OC enough to run the newer versions.
#291 8 years ago
Here are some more MET pics:
Standard Dots:
16x Upscaling:
My favorite free color file is getting better everyday
#292 8 years ago
how much Colors are possible at WPC machines
5 like dmd extender ?
#293 8 years ago
Quoted from kapsreiter:
Yes
#294 8 years ago
I've read through both threads and I still can't tell what the advantages of one over the other is.
I have a working DMD Extender in my HS2. It's limited to 2 bits / 4 colors. My only complaint is that there is tearing (where one frame is drawn at the top half of the display and the next frame on the bottom half). It's visible during animations and especially with flashing text that alternates between two colors (The Getaway *loves* flashing text .
David at Dr. Pinball said this is not possible to correct for due to the way frames have subframes and it's hard/impossible to tell which is which.
Is it possible that SmartDMD handles this better than DMD Extender?
Are there any other differences between SmartDMD and DMD Extender (that apply to early B/W DMDs)?
#295 8 years ago
Quoted from yonkiman:
This is a problem with The Getaway specifically. It tears like crazy, it's built into the game itself, it's not a problem specific to using an LCD based solution.
#296 8 years ago
Quoted from Aurich:
So (for The Getaway) I shouldn't expect to see any difference / improvements in colorization with SmartDMD than I have with DMD Extender? Just want to make sure I'm not missing anything...
#297 8 years ago
I mean, I couldn't say, but I doubt it. The issue is with the source, not the screen. SmartDMD and DMD Extender are just acting as generic displays in this case, neither of them are doing anything custom to try and buffer frames or something, if that's even possible.
#298 8 years ago
Quoted from Aurich:
I'm not aware of the game issue but SmartDmd stores each frame into a buffer before displaying it.
This is necessary for the upscaling and network features.
#299 8 years ago
Quoted from oga83:
But you're just streaming out of the buffer at the same rate the data is coming in, right?
Basically all I'm saying is the problem is in the game itself. It's hard to see how a display could change anything short of possibly some kind of custom solution specifically for the game, and that sounds like a nightmare. It's just something you have to live with when you have a Getaway.
#300 8 years ago
Quoted from Aurich:
Yes, but not exactly. There are some tricks about the display rate to avoid some (fast blinking) animations to flicker.
Quoted from Aurich:
I've never seen this game but I agree : it is very unlikely that SmartDmd will improve this kind of issue.
$ 49.00
PinballReplacementParts
Filament Printing
Other
$ 16.95
Toys/Add-ons
7,000
Sadsburyville, PA
Other
$ 24.00
Pin Monk
Other
Mitchell Lighting
Led
$ 649.95
Pin Stadium Pinball Mods
Led
NO GOUGE PINBALL™
Other
Precision Pinball prod.
Flipper parts
$ 69.99
Toys/Add-ons
$ 54.99
Shooter rods
Pinhead mods
Protection
$ 65.00
$ 24.95
Toys/Add-ons
$ 52.99
Pinball Shark
Shooter rods
8,750
Philadelphia, PA
$ 18.99
Tools
FlipMods
Tools
Professor Pinball
Interactive
$ 29.99
PR Mods
Sound/Speakers
$ 129.95
Hookedonpinball.com
Toys/Add-ons
$ 9.99
Bent Mods
Other
$ 12.95
$ 17.50
Sound/Speakers
Pinhead mods
Protection
$ 12.95
Pinball Pimp
Decals
7,000 (OBO)
Folsom, CA
$ 399.95
Led
11,250
This page was printed from https://pinside.com/pinball/forum/topic/smartdmd-dmd-interface-with-colors-upscaling-network-and-more/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
