(Topic ID: 72365)
SmartDmd : DMD interface with colors, upscaling, network and more !
By oga83
9 years ago
  • 613 posts
  • 123 Pinsiders participating
  • Latest reply 1 year ago by Cadrion
  • Topic is favorited by 152 Pinsiders
There are 613 posts in this topic. You are on page 13 of 13.
#601 3 years ago
Quoted from Nairolf:
Hi, I'm looking for the PIN2DMD 1.8 color rom for Metallica Pro real pinball.
I know this rom exist because I see this:
Is someone have any idea where I can found it or who I need to contact (not sure I can contact J_M_)
Thanks for any help.
pm sent
#602 3 years ago
Is someone have any idea where I can found irt or who I need to contact (not sure I can contact J_M_)
Colours look 100x better in real life... whoever shot that video should have done a better job of it!
3 months later
#603 3 years ago
j_m_ I'd love a copy of it as well
1 year later
#604 2 years ago
Are PIN2DMD color files similar to Smart DMD color files, I have a few smart DMD kits and want to use at least 1 for Indy 500.
Thanks.
#605 2 years ago
SmartDMD colorizations can be used with pin2dmd but you can´t use a pin2dmd colorization with smartDMD
#606 2 years ago
Quoted from lucky1:
Thanks.
8 months later
#607 1 year ago
Reading through this thread, I'm trying to understand the limitations/capabilities of SmartDMD, and it's reliability.
Specifically, there does not seem to be a solution for WPC, but there's one for Whitestar/SAM ? Or did I misunderstand ?
I'm rather puzzled however at how you can use a RPI to capture 3Mhz data using GPIOs, that kind of baffles me (I know RPI can do GPIO up to 20Mhz, but that's for output, not input).
Also one technical question on the smartdmd application itself: can it be run to output the DMD frame as a gstreamer source (so we could use a gstreamer graph for additionnal processing) ?
Regards
#608 1 year ago
Quoted from Ashram56:
Actually, it works with WPC games :
SmartDmd implements some tricks to sample the signal at 10.5MHz (Sam DMDs are at nearly 5MHz, so a 10MHz sampling frequency is needed). These tricks are hardware dependant and that's the reason why it only works with a limited set of Rpi versions that use a Broadcom chipset.
Regards
No, unless you process the frames on a separate computer with a video grabber.
#609 1 year ago
Quoted from oga83:
Thanks for these details
I assume you're using SMI (that's the only only I can think off, since the SPI signals are marked as optional), but anyway
Besides gstreamer, is there an alternative for getting the DMD frame ? Using a PC with a video grabber is way overkill for that usage... What about network broadcasting (it would be in that case a local 127.0.0.1 transfer) ? Does it transfer the entire frame or does it require specific handshake with a client SW ?
Regards
#610 1 year ago
I'm not using SMI.
I'm driving the chipset as if it was a bare metal system.
To acheive this, the Linux scheduler is disabled most of the time.
As a result, the frame broadcasting will not be as fast as it could on a normal system.
Also, this implies that you won't get much cpu time to process the frames on the same system.
You'd have to receive and process them on a different computer.
#611 1 year ago
Running smartdmd for years now and it’s quite reliable. Had two of which one worked years without any flaw and one where now and than the SD card crashed (had to rebuilt the image each time) but that was already some time ago. Had to put like a year ago a cooling fan otherwise it would quit working after like 30-60 minutes.
But, if you have a broken PI good luck finding a replacement PI as it needs this specific chipset.
#612 1 year ago
I have put SmartDMD through the races and it is kind of a miracle of efficiency.
1 month later
#613 1 year ago
Hey all... I have a Star Trek that I am thinking about doing this mod to. I was curious about which raspberry pi to use... I know it says b+ but is that rpi 3? Also, is this the way to go for a colorization for my machine? is there other products that I should check out? I don't have any issue building this up... Thanks for the help.
$ 395.00
PinWoofer
Sound/Speakers
Lighting - Backbox
Backbox
arcade-cabinets.com
Sound/Speakers
This page was printed from https://pinside.com/pinball/forum/topic/smartdmd-dmd-interface-with-colors-upscaling-network-and-more/page/13 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
