(Topic ID: 121517)
SmartDMD and Data East did anyone try it ? i have problems
By sirlonzelot
7 years ago
  • 11 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by Monster_Bash
    #1 7 years ago
    hi,
    did anyone run a smartdmd on a data east machine and can share his smartdmd.config ? also it would be helpful if you can let me know which Version of smartdmd you are running.
    i tried one in my tales from the crypt but it doesnt Show things right.
    i tested the smartdmd in my metallica and there it works. i also tested a Plasma in my tftc and that works too.
    so it must have something to do with the Settings or with the Software.
    thanks
    #2 7 years ago
    Metallica is SAM. Did you go into the settings and set it Data East?
    #3 7 years ago
    I tried it with my WWFRR and it worked fine. As Dung mentioned make sure you have the SmartDMD.txt file set to Data East. I don't remember what number it is off the top of my head
    #4 7 years ago
    I der it to Data East, but dont work. That why i ASK to Share the Config....
    #5 7 years ago
    Here is my Config
    http://i.imgur.com/dI6DkCVl.jpg
    And Thats How it looks when i Turn on the Game
    #6 7 years ago
    Which Raspberry are you using ?
    - A, B, B+ v1.x are ok with previous SmartDmd versions (until v2014-10-06)
    - B+ only for the latest SmartDmd version (v2015-02-22)
    - The latest Raspberry v2 is not working well with Stern/Sam (some glitches on the screen). I don't know (yet) for the other games (DE,...) but I feel confident it will work well as the signals are slower.
    #7 7 years ago
    I use b, but i also have b+ in my metallica and ACdc which i can try in my tftc
    #8 7 years ago
    Problem found. All Switches on the dmd Controller board have to set to on
    #9 7 years ago
    Quoted from sirlonzelot:
    Congratulation for finding this !
    #10 7 years ago
    After Building all back in my machine i had have the Same Problem. The Only thing that i change because of Testing was the Power suply, et voila After change it it Runs again . Crazy but True the Problem was this Power supply
    #11 7 years ago
    I remember needs a good PS. I bought a bunch of 2A USB adapters and they worked fine
