(Topic ID: 262672)
Small mistake. Big problem. 62V killed my 12V
By fabsj82
  • 24 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by BC_Gambit
#1 4 years ago
Hey guys. I just bought a Demolition Man with a non working DMD. While testing voltages on the DMD I looked away for a split second and bridged the 62 volt pin to the 12 volt pin. Optos went out and the game started launching balls continuously. F116 fuse was blown. I turned the game off replaced the fuse and it blew again right away on start up. I pulled the board and BR5 bridge seems to be fine. Where should I be looking next? U20 chip?
#2 4 years ago
If that were bad. Things wouldn't work. I never heard of a bad U20 blowing fuses.
I'd look to driver board problems. Even if things seem fine.
#3 4 years ago
If you want to be sure it's the board then pull J116, J117 and J118 and if the fuse still blows it's on the board. Odds are good that it's on the board.
The circuit is quite simple. The bridge rectifier is rated for 35A and 200V. The capacitor is rated for 15,000uF but only 35V.
#4 4 years ago
I'm sorry to hear this happened to you, the bridge rectifier will be fine as it was immediately placed into a reverse biased condition, Unfortunately, the list of potential damage is quite large as F116 didn't blow until other components on your +12V line failed in a bad way.
Parts that were hit with 62V:
Fliptronics II board - LM339 absolute max voltage = 36V
Trough boards - LM339 absolute max voltage = 36V
7 Opto board - LM339 absolute max voltage = 36V
DC Motor control board - LM7805 absolute maximum voltage = 35V
All optos and boards with optos - Flipper boards, trough transmitter, claw opto board, elevator opto board
#5 4 years ago
Quoted from DumbAss:
Thanks! Pulled J116, J117 and J118 and the fuse did not blow on power up. Do you have a recommended order to go in to start narrowing down the culprit?
#6 4 years ago
Quoted from fabsj82:
Put them on one at a time (with the power off) ... my guess is J118 will blow the fuse. Does your 12V LED on the power board light?
#7 4 years ago
Actually, if you were checking this on the DMD, you likely only blew out your DMD board as the DMD controller board has a blocking diode on the 12V line which would prevent the 62V from back feeding to your power board. Try just leaving the DMD display disconnected
#8 4 years ago
Quoted from Pin_Guy:
All LEDs match my Getaway except LED3 is lit solid and light on DMD driver board is off.
#9 4 years ago
That was the first thing I tried. Fuse blew right away
#10 4 years ago
#11 4 years ago
J117 is my fuse blower.
#12 4 years ago
Your +12V only passes through the Dot Matrix controller, I'm surprised these components didn't block it....
I may have misread the specs on display driver board Zener Diode D8 (1N4742), it may be shorted and sending your 12V to ground, disconnect J606 on the display driver to verify.
#13 4 years ago
disconnect J606
Disconnected j606 and plugged in j117. Fuse did not blow. What are the chances I blew up my display as well? Of course I had my one known good one in there at the time.
#14 4 years ago
I've never worked on one, but since that's your operating voltage several on the IC's on the board, I would give it a high probability.
As far as the Controller board, I would test both D7 and D8 with your meter in diode test. D7 is probably ok but it did push a lot of current, personally I would just replace both D7 and D8.
EDIT: After reviewing the schematics a bit further, the above statement only applies if your display has a Babcock driver PCB; if you have a Cherry PCB board, it has no connection to +12v as it uses +5V for all IC's so it should be fine.
#15 4 years ago
Important information!
#16 4 years ago
#17 4 years ago
#18 4 years ago
I have no idea.
#19 4 years ago
I have no idea
Lol. Thanks a ton @Pin_Guy I really appreciate all your help. I'll take this as a win for the night. I can start a game, flippers are acting weird but I should be able to take it from here. Thanks again!
#20 4 years ago
Confirmed. Vishay APD=128G032 DMD does not use 12V. I dodged a bullet!
#21 4 years ago
For sure, only out one $0.26 diode
#22 4 years ago
Wow! A really great repair log so far. And a reminder I need to buy better test leads for my multimeter. Yikes!
#23 4 years ago
Quoted from BC_Gambit:
Definitely don't rely on notches in the probe and don't have three kids running around the machine while you are using it
#24 4 years ago
https://www.amazon.ca/Automotive-Insulation-Crocodile-Multimeter-Certificate/dp/B07489TJMS
Hopefully that link works
Some of the pieces in this kit look like a good upgrade for me. Others might even have a better idea.
$ 39.99
Mitchell Lighting
3,250
Bethlehem, PA
4,600
Ponte Vedra Beach, FL
$ 18.95
$ 72.95
$ 18.00
Volcano Pinball
3,700 (OBO)
Monroe Township, NJ
Metal-Mods
$ 45.00
86Pixels
$ 35.95
Mitchell Lighting
YouBentMyWookie
4,690 (Firm)
La Porte, TX
$ 40.00
$ 199.95
PinSound
$ 5.00
$ 329.99
$ 85.00
KAHR.US Circuits
$ 9.95
$ 12.00
Tools
Nezzy's Pinball Prints
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/small-mistake-big-problem-62v-killed-my-12v and we tried optimising it for printing. Some page elements may have been deliberately hidden.
