Quoted from RobKnapp:Thanks . I am still unclear # 3. I love skillshots. Hold right flipper got that part. If the ball feeds back to the flipper hit ramp . Can you explain this for me more in depth . Thanks ectobar.
Sure thing.
Past the jets, there is a diverter/button (I'm probably using some off terminology here, sorry). If you hold the right button, that diverter stays in place. The goal is for the plunge to bounce off of that, go back past the jets, and then feed down to the flipper. If you hit the warp ramp, you get 1.6mil. The problem is that it often doesn't bounce off the diverter hard enough, and ends up going into the jets, negating your chance at some extra points. On my machine, a hard manual plunge seems to get the job done around 50% of the time, where as using the fire button is even less.
