In need of help diagnosing an issue I’m having with my Slugfest.
The second I swing the bat regardless if it hits a target switch or not, it calls a strike. Likewise, if I don’t swing the bat it will call a ball
It happens with all four pitches, however much less frequently with changeup switch and screwball. And almost every time with fastball and curveball.
I have replaced the strike trough switch thinking that was it, no change. I tried swapping power driver board, also CPU board… with known good boards. No Change!
I looked over the wiring harness, and all looks good.
I also tested all the switches in test mode, and everything checks out A-Okay
Lastly, I looked through the 18 pages! Of Slugfest club posts and nothing matching my issue.
Very perplexed and could use some help!
