Quoted from Pclusk:When the machine does a self-test, it comes back with a Fast Ball Pitch error where it lists the switch as closed when the button is not depressed. When the Fast Ball button is pressed, it does properly throw the ball...
Maybe a matrix issue. If other switches were pressed at that time in the same row/column with a bad diode it would read as the incorrect switch.
