Quoted from PtownPin:Let me know....did you buy the two in the back box along with the cheap sub in the bottom of the cabinet?
The game has a 6" cabinet speaker and a 4" speaker and the same 6" speaker in the backbox.
Standard speakers 2@ 6", 8 ohm, 20W & 1 @ 4", 8 ohm piezo, 50W.
I bought 1@ 6.5", 8 ohm 45W, 40Hz-7kHz for the cabinet and 2@ 5", 50W, 8ohm, 80Hz-15kHz for the backbox from Newark.
I haven't put in the cabinet speaker yet, but I did put in the backbox speakers. Neither of the new speakers fit the existing openings, so I had to make adapters.
The 5" to 6" adapter was easy, make it out of about 0.2" plexy.
Speaker installed with plexy adapter:
5" speaker with wooden adapter to fit 4" hole:
I'm planning to make a better 4" to 5" adapter, but a 2x6 is what I had on hand that I thought would be thick enough. It was a challenge trying to make a conical cut in the 2x6 to match the 2 hole sizes. I didn't want to cut a larger hole in the speaker panel until I lived with these for a while.
It sounds better. I like that the 2 BB speakers are the same size and output. The existing 4" tweeter had almost no output.
I'll probably post a bit more after I put the cabinet speaker in.
Robert
