(Topic ID: 325417)
Slowly pulsating on/off LEDs?
By frenchmarky
4 months ago
    #1 4 months ago
    Does anybody make an LED that gradually goes from off to on and off again like in one or two seconds, instead of just blinking? I was thinking that would be a cool effect to use in certain insert lamps instead of just being solid on or off. Say you have 2X/3X/4X/5X bonus multiplier lamps where only one is lit at a time, would draw more attention to it, say on an early SS game. A slow pulsating sort of effect. I know there are blinker and 'flame/flicker' LEDs but I'm not aware of something like this. Not something to put all over the playfield but... Maybe it would be difficult to fit the circuity needed into the lamp base, I dunno.
    #2 4 months ago
    I'd guess they exist, but a quick search turned up only an RGB color-changing version of what you want. I.e. instead of fading in and out, it just slowly shifts through the rainbow.
    Are you set on a self-contained bulb. The Internet is full of example projects, mostly using the classic 555 timer chip, to fade LEDs in and out. Depending on how the bulbs in your machine are wired, you might even get away with a single timer circuit for a whole array of bulbs. But barring that, as long as it's not that many bulbs, you might find it acceptable to just create enough copies of the circuit to wire up each individual bulb with one.
    #3 4 months ago
    Interesting videos out there on how to do it with that chip. An LED that came on instantly but then slowly faded out would be neat too, with more of a 'warning' look to it. I'm thinking of the indicators in the movie '2001' when HAL is turning off the life support of the passengers in hibernation.
    #4 4 months ago
    Quoted from frenchmarky:
    With the right combination of resistors, capacitors, diodes, and the 555, you should be able to create just about whatever lighting effect you want.
    Alternatively, for a higher expense in hardware (though not much) and IMHO a slightly more intuitive approach, you could use an Arduino controller. Depending on the exact microcontroller, i.e. how many I/O pins it has, you can set one up to control many lamps, and while learning the basic Arduino ecosystem isn't trivial, the actual programming is probably easier to understand than trying to figure out resistor and capacitor values that do what you want with a 555 circuit. In Arduino, you can just set up a loop that explicitly sets the LED brightness to whatever specific value you want over time.
    Granted, none of this is nearly as easy as just finding an LED already designed to do what you want. I've never heard of such a thing, but I'm far from an authority on the subject. If no one else here has any ideas, maybe you just have to do more web searches, or post in different forums that are more dedicated to electronics and/or LEDs specifically. In a pinball forum, it's a pretty niche question, but in an electronics forum, it might be borderline FAQ.
    #5 4 months ago
    I did find a lot of stand-alone LEDs (with leads) including warm white and colors called 'breathing/fading', they would also require a resistor in the circuit. The cycle looks to be about 3 seconds, mostly full on with the fading down and back up a shorter portion of the cycle. A bit slower than what I was thinking for pinball use, they are used for when a device is in 'pause' mode. Might be a good effect for certain backglass lights. Didn't find anything in a 44/555 lamp yet though.
    This page was printed from https://pinside.com/pinball/forum/topic/slowly-pulsating-on-off-leds and we tried optimising it for printing. Some page elements may have been deliberately hidden.
