(Topic ID: 184527)
Quit wasting fuses! Affordable breaker reference w/ Mouser links
By goingincirclez
2 years ago
  • 45 posts
  • 29 Pinsiders participating
  • Latest reply 2 years ago by Drewscruis
  • Topic is favorited by 39 Pinsiders
    17
    #1 2 years ago
    In discussing troubleshooting on another post I made, I mentioned using a number of circuit breakers I had on hand, then got a couple of PMs asking about them, so....
    Ever burn through a 5-pack of fuses all too quickly while chasing down a trouble spot? Ever burn your last one after the local stores are closed? Ever go to the store only to discover the size you need is apparently the one oddball they do not carry or is out of stock (of course!)? Ever suffer the first-world anguish of a game down for days while you wait for "just a fuse" to be shipped?
    Yeah, it sucks. And this, incidentally, is how games get overfused with whatever is on hand, which is even worse!
    So stop it because circuit breakers are amazing! For just a buck or two more than a 5-pack of fuses you can plow through in a hurry, you can get an infinitely re-usable breaker that will keep you from literally burning that money the next time something goes wiggedy whack wrong.
    Mouser has a whole range of them:
    FS=True">http://www.mouser.com/TE-Connectivity/Circuit-Protection/Circuit-Breakers-Accessories/Circuit-Breakers/_/N-axfui?P=1yzs6ii&Keyword=circuit+breaker&FS=True
    Simply search for the amperage you need, and choose a push-to-reset model. Here are the common sizes I have found handy:
    2A: http://www.mouser.com/ProductDetail/TE-Connectivity-PB/W58-XB1A4A-2
    2.5A: http://www.mouser.com/ProductDetail/TE-Connectivity-PB/W58-XB1A4A-2.5
    3A: http://www.mouser.com/ProductDetail/TE-Connectivity-PB/W58-XB1A4A-3/
    4A: http://www.mouser.com/ProductDetail/TE-Connectivity-PB/W58-XB1A4A-4/
    5A: http://www.mouser.com/ProductDetail/TE-Connectivity-PB/W58-XB1A4A-5/
    7A: http://www.mouser.com/ProductDetail/TE-Connectivity-PB/W58-XB1A4A-7/
    8A: http://www.mouser.com/ProductDetail/TE-Connectivity-PB/W58-XB1A4A-8/
    10A: http://www.mouser.com/ProductDetail/TE-Connectivity-PB/W58-XB1A4A-10/
    There are lots of other sizes available....
    To use them you need to save your blown fuses. Solder the breaker lugs to a bad fuse. The simply insert the fuse breaker as required, and troubleshoot away. (I will post a photo of mine later on).
    The first time you reset one three times, it will have paid for itself in spared fuses, saved time and fuel, convenience, and peace of mind. The assortment of breakers I listed above cost me maybe $40 and has been one of the most valuable bits of kit in my toolbox.
    #2 2 years ago
    Awesome! Thanks for the links.
    #3 2 years ago
    I made a set like 1.5 years ago. Came in really handy troubleshooting a sys 7 issue that was burning through fuses. Very handy maintenance tool to have on hand.
    #4 2 years ago
    Great info, thanks!
    #5 2 years ago
    Great stuff, thanks for sharing!
    #6 2 years ago
    Great thread, thank you for posting this information.
    -Kyros
    #8 2 years ago
    One thing Ive found is the circuit breakers takes a little bit more to trip than a corresponding fuse. I would try to use a slightly lower amp rating (let's say a 10 amp circuit breaker for a 12 amp fuse)
    Mike V
    #10 2 years ago
    That little device has been around for years. Nice of you to post as it looks like quite a few people were not hip to it, and now more will be!
    #11 2 years ago
    I little pricey. You can also look in other places to save $:
    I actually saved some $ by ordering these types of breakers on e-bay. Search under "boating breaker" or "boat breaker" and not fuse or relay.
    It pays to look for these items through non-pinball sellers.
    I ordered like 20 different values for $2 each from a few different eBay sellers. FREE shipping too.
    These breaker fuse relays are also used in small planes. known as "avionic breakers" or "thermal breakers"...
    I found most of them from eBay sellers with lots of boating supplies.
    I once found some AIRPAX avionic breakers for like $1 each on eBay. They were military grade, out of an old fighter jet from the 70's that someone was parting out. Built so well that you could accidentally run them over with your vehicle and they will still funtion.
    #12 2 years ago
    Aww damn, I need to get me some fighter jet breakers now
    I'm sure most folks figured it out, but as promised here's a photo of the fuses soldered to the breakers.
    #13 2 years ago
    Quoted from goingincirclez:
    I saw that pic and thought those were mine for a min. I did the same thing exactly with the rating done with white paint pen on the side and soldered bad fuses to them. Exactly.
    #14 2 years ago
    Please forgive my ignorance here but how do we know if the breakers are fast blow or slow blow?
    #15 2 years ago
    The button pops out.
    #16 2 years ago
    Quoted from RacingPin:
    Mike V
    This is great advice. They trip slower and can cause problems; we burned a ground trace once with one of these it took so long to pop.
    #17 2 years ago
    ALWAYS use 1 amp less than required when using these! They absolutely take longer to blow than a comparable fuse. If using in a fast blow application I would use even 2 amp less. better to have to hit the switch than repair the board.
    Also solder alligator clips with lead wires instead of blown fuses then it is good for all fuse types and sizes. Been using mine for many years on all generations of boardsets ... LOVE them.
    #18 2 years ago
    Could have saved you some time. Just did the same post last month. They work great.
    https://pinside.com/pinball/forum/topic/push-button-resetting-circuit-breakers
    hawk007 That is what I recommend also. Use either 1amp less or 1/2 amp less. They are all slow blow.
    #19 2 years ago
    Quoted from CaptainNeo:
    Heh... silver sharpie, white paint, it's all the same... I'm glad to be in good company
    Quoted from Hawk007:
    That's not a bad idea in concept... come to think of it, I don't think I've ever yet used these in a fast-blow application to where I would have paused to consider it. But then how often would being too low a rating cause it to blow when the circuit is otherwise fine, just running within the higher (normal) spec? Would hate to end up chasing "false positives" because a too-low fuse keeps blowing. OTOH maybe that's better than something else getting damaged...
    #21 2 years ago
    You boys and your breakers. I made one of these, good for up to 5A
    http://nutsvolts.texterity.com/nutsvolts/200909/?folio=42&pg=42#pg42
    #22 2 years ago
    You mean all those people that kept telling me over the years repeatedly to use a piece of rolled up piece of tin foil for testing were wrong?
    #23 2 years ago
    I saw Clay use these years ago, I assume he's the first? Or did he pick it up from someone else?
    #24 2 years ago
    Here's one made of metal like I was talking about. They are from the 70's-80's.
    ebay.com link » 1 Airpax Api 1 5 1 502 5 Amp Dc Breaker Switch Used
    #26 2 years ago
    Quoted from xTheBlackKnightx:
    tin foil? Novice. everyone knows you are suppose to use full metal jackets.
    #27 2 years ago
    I picked up a few of these a while back from Ed at Great Plains. I haven't used them yet - but I am glad to see the pics and info about soldering a fuse and other tips on amps, etc.
    #28 2 years ago
    do not solder a fuse to it. Use alligator clips with lead wires so it works on all types and sizes of fuses in any location. see my earlier post.
    Cheers!
    #29 2 years ago
    When I made mine I had soldered fuses to my set... a lot easier than fumbling with alligator clips, but good point about the different size fuses. Fortunately this works for 99% of what I typically work on.
    Now that you mention it though might go ahead and make another set with clips though just so I'm not caught with my pants down.
    Was this originally a Bob Roberts tip? I remember having had read it somewhere once upon a time.
    #30 2 years ago
    I have some of these made up.
    I used a 3 amp one in a 5 amp location when troubleshooting a pop bumper on my BK2000.
    Ended up burning out the coil.....didn't pop nearly as early as it should have.
    Not sure they are great for every condition like this.
    John
    #31 2 years ago
    Quoted from Drewscruis:
    That is the coolest thing ever! I am so doing that. I have wanted to get the breakers for years, but Ed was always out.
    faz
    #32 2 years ago
    Wow! Thanks johnjones that thing is awesome... have to build myself one of those now.
    #33 2 years ago
    I always like the 10 X24 option:
    #34 2 years ago
    Quoted from girloveswaffles:
    Can I use metric too??
    faz
    #35 2 years ago
    Quoted from pinball_faz:
    faz
    Only on re-imports from Europe. Then you have to use a #8-14.
    #36 2 years ago
    faz
    I contacted the designer, and he still has boards available. his email is sjnewt@att.net
    #37 2 years ago
    that's pretty cool, but only goes up to 5A. Which really limits it's use. if they had one that went up to 20A that would be awesome.
    #38 2 years ago
    I contacted the designer about possibly designing one that has a higher amperage range. This is good for the smaller amp(5 and below) situations. Any suggestion on the range for fuses?
    #39 2 years ago
    for pinball you use 3/8 A up to 20A
    #40 2 years ago
    Just solder 2 full metal jackets together...
    #41 2 years ago
    Most of my stuff only goes up to 10 amps. I would think you would be more worried about the maximum wattage. If it could handle up to 400 watts, that would be pretty good. If blank boards were made available, I would buy one in a heart beat.
    #42 2 years ago
    Ok, we have a lot of EE types here.... How about a Pinside Group Project!!
    I've heard some pretty cool requirements:
    Variable range covering from - 3/8A thru 20A
    400 Watt upper end
    Digital readout
    Is there a way to simulate "fast blow" as opposed to "slow blow" or per Hawk007's comment, is it enough to just dial back the rating. (not a EE... sorry if that's a stupid question).
    Can we extend the original plans to increase capability?
    I'd really like to build this myself... this looks like a fun project.
    faz
    #43 2 years ago
    hey faz, great idea.
    We could use it all the way down to 1/4 amp or even 1/16 of an amp for testing hv circuits.
    #44 2 years ago
    The docs in the download mentions it can be upgraded to support 20 amps. A few parts need to be changed, but you'll need to contact the author to get an updated micro code:
    http://www.nutsvolts.com/uploads/magazine_downloads/refuseable.zip
    #45 2 years ago
    Quoted from Quench:
    I sent him a message and am waiting for him to get back to me. Will let you know what he said when he does.
    $ 839.00
    $ 2.00
    Doc's Pinball Shop
    $ 9.95
    $ 156.50
    $ 9.90
    pinballmod
    $ 26.50
    $ 14.50
    PinballElectronics.com
    $ 27.99
    $ 11,500.00
    $ 69.99
    $ 45.99
    $ 45.00
    Just 3D Mods
    CzTV Mods
    $ 18.99
    $ 2.50
    Doc's Pinball Shop
    £ 58.00
    $ 7,599.00
    Classic Game Rooms
    $ 109.99
    $ 48.00
