(Topic ID: 232588)
Sloppy Match - '76 Surfer
By jfranci
1 year ago
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Runbikeskilee
#1 1 year ago
Hi all! At times, my '76 Surfer incorrectly awards a match credit when the the match digit is off by 1 position. For example, it may give a match when the final score ends in '10' but the match value displayed is '00'. I pulled the match unit out of the back box and noticed there's some play on the rotating arm which determines the match value (A on photo). It appears to me the arm is held in place by pressure from the clip (B). I've tightened the mounting screws (C) but that's not helped. Any ideas? Thank you!!!
#2 1 year ago
This is known as an AS relay and is a remarkably versatile and tiny stepper that can be really fiddly to adjust properly. Here are Gottlieb's instructions:
https://www.ipdb.org/files/2233/Gottlieb_1975_Soccer_AS_Relay_Adjustment_A_11492.pdf
You may also find other topics here about this device with a little searching.
I would start by cleaning the wiper board and contacts to see if that helps. Like any other stepper you should be able to pull the armature all the way down, let it go, and have the stepper advance cleanly to the next position. If yours isn't doing that have a close look and see if it's stepping too far (more than a full step) or if it's rebounding and stepping back a bit (or less than a full step). That would help determine what adjustment to make.
Beware that this isn't a device that responds well to a shotgun approach. I wouldn't adjust any more screws until you have a better idea of why it's not precise because the adjustments for back sliding and overstepping are different. Once you know which way to go only loosen screws just enough to get the adjustment you want, make a tiny change and then snug them up again and test to see if things are working better. It may take a few tries to get it dialed in.
/Mark
#3 1 year ago
Great advice Mark G, I would also add that even with all the proper adjustments there can still be issues with a sloppy match unit. This can occur when there is too much play between the nylon Center spindle (labeled B in the diagram above), that attaches to the ratchet and. Snowshoe (labeled a in the diagram above.) 00-90 units that may have been abused, or have seen heavy use, could exhibit this behavior. It is tricky to repair. Check to see how much play there is between that nylon Center spindle and snowshoe arm. I have had some success with bending out the tabs on that arm that engage the spindle also, adding some Thin metal shims is it another option.
#4 1 year ago
Does the machine improperly award a match on both players?
The reason I ask is that there are multiple wipers involved in the match circuit. In order to award a match correctly, the wipers on one of the tens score reels have to line up on the same number that the match stepper finishes up on. If any of these wipers (score reels or match stepper) are misaligned or bent such the contact straddles two copper traces, one can get the issue you have noted. The issue might also occur is there is anything conductive that might be shorting 2 adjacent copper traces together.
That said, the issue is MUCH more likely to happen with the match stepper wiper & circuit board due to it's design, tiny size, and the close proximity of the traces to each other.
Mark and Stashyboy offer good advice wrt cleaning the match stepper copper traces and trying to mitigate any play between the spindle and the wiper fitment.
L
Various Novelties
GC Pinball
$ 245.95
Allteksystems
$ 18.99
$ 48.00
$ 49.00
$ 19.99
PinballElectronics.com
$ 219.00
$ 5.00
Various Novelties
GC Pinball
Pixels Arcade Games
$ 99.99
$ 109.99
$ 3.00
Doc's Pinball Shop
$ 99.95
Hookedonpinball.com
$ 69.50
$ 135.00
Cabinet - (Alt) Translites
Lit Frames
$ 90.00
Lighting - Under Cabinet
$ 19.99
$ 34.99
Cleaner
Pinball Pro
