(Topic ID: 48637)
Slingshot on a Getaway
By clg
11 years ago
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 11 years ago by LTG
#1 11 years ago
Just hoping for a confirmation of a diagnosis before I order a part. Right slingshot on a getaway is not working. Switch tests out fine. When I run the solenoid test it will not fire. I tested the voltage on the solenoid and I only get voltage from one of the terminals. On the other solenoids I get voltage from all of the terminals. Does this then mean the problem is the solenoid itself or do I need to do further testing?
#2 11 years ago
A couple thoughts. You could ground the transistor ( metal tab on top ) briefly and see if it fires. If not you have a break in wiring from the transistor legs to and including the coil.
Me - I would dig around the solder joints at the coil lugs, dig around the tiny wire going from the coil to the coil lug. Easy to have a hard to see/find break there.
If you ground the transistor tab and it fires, then the transistor and across the board to the ribbon cable to the CPU is suspect.
#3 11 years ago
Thanks! Sorry to be clueless but I am not sure what you mean by the transistor. Is this on or attached to the coil itself?
#4 11 years ago
Never mind google solved the transistor tab question!
#5 11 years ago
Coil would not fire when I grounded it so that definitely narrows it down. Thanks!
#6 11 years ago
Quoted from clg:
Well done. YouTube can be a great resource too.
$ 28.99
Lee's Parts
$ 17.99
$ 19.00
NO GOUGE PINBALL™
G-Money Mods
$ 225.00
Professor Pinball
$ 69.00
Pinball Pimp
$ 70.00
RobTune
$ 75.00
G-Money Mods
$ 19.00
Tilted Pinball
Louisville, KY
$ 22.50
$ 109.99
Playfield - Plastics
$ 72.50
$ 120.00
G-Money Mods
$ 329.99
$ 65.00
G-Money Mods
$ 12.50
$ 16.00
5,650 (OBO)
Fontana, CA
Fort Lauderdale, FL
4,550
Melbourne, ON
$ 9.95
This page was printed from https://pinside.com/pinball/forum/topic/slingshot-on-a-getaway and we tried optimising it for printing. Some page elements may have been deliberately hidden.
