(Topic ID: 78301)
Slide relay switch adjustment - are these as out of adjustment as they look?
By alb0711
10 years ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 10 years ago by alb0711
    #1 10 years ago
    I'm shopping my 1955 Bulls Eye and it has 2 banks of what I am calling slide relays (not sure if that is really the name?). The machine works 90%, but several minor features are either not working or intermittent. I pulled the slide relay banks from the housing so I could get a close look for adjusting and cleaning. I've had success with other EM machines switch adjustments by simply looking for "state changes" when the relay is energized.
    Taking a close look at these however it appears that most of the switch contacts are seriuosly out of adjustment. The first photo is the switch as it looks when the relay is not energized and the second is what I believe they look like when the relay is energized by using my fingers to move the relay into an energized state.
    My theory is I'm either not looking at this right because if the switches were as bad as they appear, I'd have a lot more issues with the machine then I am having.
    I appreciate the help!
    Allen
    #2 10 years ago
    #3 10 years ago
    Only the very top contact position appears to be correct as it takes it from NC to NO. All the other contacts currently appear to be NO then are NO when energized. Looks like they should all ne NC and then all should be NO when energized.
    #4 10 years ago
    It almost looks like the switches are all 1 slot too high on the armature but now that i look closer there no extra slots.
    Is the armature resetting all the way?
    Also it looks like that armature is taller than the ones next to it??
    Odd
    --Jeff
    #5 10 years ago
    I agree - it is very strange. And since most things seem to work - there must be something wrong with the way I'm looking at this. I'm going to reconnect the jones plugs and leave the relay bank outside of the machine and observe what happens when it activates and resets. I'll report back.
    #6 10 years ago
    Hooked the relay bank back up to the machine last night and observed - the switches are going in the opposite direction of what I simulated by manipulating the relay armature with my fingers. The contacts are pulled down, not pushed up which explains the odd angles. Still trying to find a way to simulate the "pull down" so I can clean and adjust the contacts.
    #7 10 years ago
    Relay bank is a latch release system. Once I figured out how to release the switch banks, they were easy to adjust - and in pretty good shape for something made in 1955. Pretty cool old technology!
    #8 10 years ago
    very cool. could you post some pics of the latch release part?
    --Jeff
    #9 10 years ago
    Sure!
    1st photo is the switch bank
    2nd photo the switch bank in reset (normal) position
    3rd photo switch bank after latch
    This page was printed from https://pinside.com/pinball/forum/topic/slide-relay-switch-adjustment-are-these-as-out-of-adjustment-as-they-look and we tried optimising it for printing. Some page elements may have been deliberately hidden.
