I’ve had an issue develop with my Slick Chick. It was working fine, but suddenly the side rollovers (1,2,3 and 4) stopped scoring 30 points. The number lights work properly, that is sequentially go out which lights the special hole, but no 30 points per rollover. Relay “Z” (30 point relay) looks fine, ie soldered joints intact and switches cleaned and in alignment. The Z relay triggers appropriately when rollover switch is made (all 4) and score motor rotates 120 degrees. I checked the score motor switches as best I could since it is not a flip up type, but is bolted down to the box. But the 50 point targets (Slick, Chick and SlickChick) are working and scoring properly. Attached are a few schematic sheets. Any thoughts or ideas? My thanks in advance.
56EF29F6-ED47-4B9A-8393-C7733C1F4564 (resized).jpeg9AB2CA39-5931-418B-9B52-84D85A07FE31 (resized).jpeg7909F76F-FFD7-4086-AD74-0F19A13539C1 (resized).jpeg8162B05A-CEE6-48C7-8BD0-F22B02852F0F (resized).jpegimage (resized).jpgimage (resized).jpg
