This restore has taken a lot longer than usual. There is a lot going on under the hood with this game.
Finally was able to get the innards finished and finally got on with the cabinet. It was a good cabinet painted over with a white paint and red splatter. Was able to find the original paint underneath and got a good red under a leg and blue sample for mixing inside the cabinet.
Used a Krylon silver marble can to add the webbing mixed with a little bit of thinner per Boilerman's recipe and applied through a spray gun. Think Pinhead52 does it this way to.
The cabinet was solid except the front that was delaminating, warped and needed major loving to fit back properly.
So after much filling using Bondo and tried the Half Time product too.
First the priming using cheap auto paint. Did the spraying in my new spray booth.
Sanded smooth and then sprayed the base coat. Not stark white but a nice Ivory color.
Then the webbing. Wow, was I uncomfortable but it was the easiest part of the work.
Painted with over spray (not intended) and started to put together.
