(Topic ID: 211261)
Slammed by Switches
By JojoButterbean
2 years ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by D-Gottlieb
#1 2 years ago
Hi Everyone,
I'm still troubleshooting my Gottlieb 300. I've acted upon some of the advice from a couple of you.
I do have the schematics and have checked the H, T and AX relays.
It was running great and then just suddenly stuck on TILT.
I've wiggled the slam switch and ball tilt mechanism. No change
When somone says "adjust" the switches....how exactly is that done? How do I open or close anything?
Thank You
#2 2 years ago
The tilt light comes on when the Tilt Hold (H) relay is off. The Tilt Hold (H) relay turns off when the Tilt (T) relay comes on or some other things that are a little more complicated to describe. Do you need a phone call?
#4 2 years ago
In your other topic you were presented with a link on how to clean switches. To own an EM is to work on an EM. Everything you need on how to adjust and clean switches is here.
http://www.pinrepair.com/em/index2.htm#clean
#5 2 years ago
Where are you located?
Maybe easier to have some hands on training.
#6 2 years ago
#7 2 years ago
Let's get this down to one thread, for many reasons. Can you delete the other one?
#8 2 years ago
wow, thanks everyone. I am working on the first response..
Thank You!!
#9 2 years ago
I fixed it!!!
It was the scoring reel the whole time.
One reel was still barely on 9, therefore the machine tilted.
I manuallty cleaned and rolled the reel to 0.
Thank you everyone, I really appreciate the help.
Jojo
#10 2 years ago
Umm, the score reels are not related to the tilt problem. Somehow, your tilt issue went away, probably due to a dirty contact that is now working. The problem may return. That is, if the issue is simply a Tilt light on with nothing else happening at the same time. The score reels do need to reset to zero. Otherwise the score motor will keep running and lights will flash, not a tilt problem.
$ 49.00
$ 40.00
Arcade Arts
$ 22.00
$ 42.00
The MOD Couple
$ 29.95
Pinball Photos
$ 79.00
$ 233.10
PinWoofer
COINTAKER.COM
$ 214.99
CzTV Mods
$ 29.95
Apparel - Unisex
The GameRoom Store
$ 4.49
$ 27.99
Metal-Mods
$ 16.50
$ 10.95
$ 19.95
Pin Monk
$ 160.00
Cabinet - (Alt) Translites
Lit Frames
