Hey guys,
Getting a Slam Tilt Switch Stuck Closed on TAF. Here are current observations:
1. Tried a new Slam Tilt Switch from FT that I know works and same issue occurs.
2. Switch is not physically closed (i.e. verified switch leafs were not touching)
3. When "buzzing" with a multi meter from one of the leafs on the slam tilt switch to the ground braid I get continuity but typically only when the game is turned on?!?!
4. No row ground shorts in switch test mode
5. Unplugging the coin door from the PCB board at the front of the cab CLEARS the error.
Thanks for any help you can provide!!
Craig
